电子发烧友论坛|
你好,
我正在研究一个项目是使用M24LR NFC设备作为目标温度传感MCU和CR95HF阅读器之间的中间通信设备。我们不需要“高带宽”吞吐量,只是偶尔需要通过M24LR“RF可见”eeprom存储器传输数据。我们想知道是否需要对数据包采用前向纠错,因为我们不确定EEPROM的可靠性。该数据表引用了1,000,000个周期的“最大写入耐久性循环耐久性”。这个数字是否意味着在预期发生单个故障之前,可以对eeprom块(4个字节)执行1,000,000个擦除/写入周期?我们需要一个FEC系统吗?我们应该采用“磨损均衡”技术来循环记忆而不是连续写入同一区域吗?任何关于此事的澄清将不胜感激。 非常感谢, 德里克 #NFC标签的5型 以上来自于谷歌翻译 以下为原文 Hello, I am working on a project is using the M24LR NFC device as an intermediate Communication device between a target temperature sensing MCU and the CR95HF reader. We do not require a 'high bandwidth' throughput, only occasionally will we need to transmit data through the M24LR 'RF visible' eeprom memory. We would like to know if we need to employ Forward Error Correction with our data packets as we are unsure of the reliability of the EEPROM. The data sheet quotes a 'max write endurance cycle endurance' of 1,000,000 cycles. Does this figure mean that 1,000,000 erase/write cycles can be performed to an eeprom block (4 bytes) BEFORE a single failure is expected to occur? Do we need a FEC system at all? Should we employ a 'wear leveling' technique to cycle through memory rather than writing to the same area continuously? Any clarification on this matter would be appreciated. Many thanks, Derick #nfc-tag-type-5 |
1个回答
亲爱的德里克,
如数据表中所述,1,000,000个周期的“最大写周期耐久性”表示一个存储单元的最大写周期值(写入不保证高于此阈值)。 1个写周期意味着同时写入1个字节,2个字节,3个字节或4个字节(1页)。 如果单元的写周期总数低于最大写循环值,则可以在没有任何约束的情况下写入数据。否则,应使用特定的写入程序(数据重新分配策略)。 请注意,对于25摄氏度的工作温度,给出1,000,000个循环值。温度上升时,循环耐久性会下降。例如,最大循环耐久性在85℃时减少到150k写入。 最好的祝福。 以上来自于谷歌翻译 以下为原文 Dear Derick, The 'maximum write cycle endurance' of 1,000,000 cycles, as written in the datasheet, means the maximum write cycling values for one memory cell (write is not guaranteed above this threshold). 1 write cycle means the writing of 1 Byte, 2 Bytes, 3 Bytes or 4 Bytes (1 page) simultaneous. If the total number of write cycles for a cell is below the max write cycling values, data can be written without any constraint. Otherwise, specific writing procedure should be used (data reallocation strategy). Please be aware that the 1,000,000 cycles value is given for an operating temperature of 25 degrees Celsius. Cycling endurance is decreasing when temperature is rising. For instance, max cycling endurance is reduced to 150k writes at 85C. Best regards. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 20:12 , Processed in 0.676613 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2042
