电子发烧友论坛|
我正在使用IDE 13.4并试图让多引导工作,但我被卡住了。
iMPACT崩溃或无法映像m * * .mcs文件同时包含我的位文件。 我可以单独加载到ISE并启动多重启动。 我还可以加载应该转到内存位置0的位文件,然后使用JTAG加载第二个位文件并让它从ISF触发重新配置。 我不能做的是将两个文件加载到ISF上,以便它们可以来回触发。 我已经设置了我的bitgen选项,以便第一个位文件知道它应该多引导到内存位置0x0C0000,第二个位置知道多引导回到0x000000。 我认为我的问题是PROM发生器,但我不确定。 我已经完成了多引导设计,并且能够加载预先生成的* .mcs文件,我无法自己创建 一些原因。 有没有人得到自定义多重引导版本? 以上来自于谷歌翻译 以下为原文 I'm using IDE 13.4 and trying to get multiboot working but am stuck. iMPACT either crashes or is unable to image m y*.mcs file conataing both my bit files. I can load both onto the ISE individually and initiate multiboot. I can also load the bit file that's supposed to go to memory location 0, then load the second bit file using JTAG and get it to trigger the reconfigure from ISF. What I can't do is get both files loaded onto ISF so that they can trigger back and forth. I've set my bitgen options so that the first bit file know its supposed to multiboot to memory location 0x0C0000 and the second knows it multiboots back to 0x000000. I think my issue is the PROM generator but I'm not sure. I've worked through the multiboot design at http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm and was able to load the pre-generated *.mcs file, I just can't make my own for some reason. Has anybody gotten a custom multiboot build to work? |
2个回答
所以,我想出了自己的问题。
不要使用iMPACT,请使用命令行。 这是我汇总的一份快速文档,引导您完成整个过程。 Multiboot Procedures.docx 133 KB 以上来自于谷歌翻译 以下为原文 So, I figured out my own problem. Don't use iMPACT, use the Command line. Here is a quick document I put together that walks you through the entire process. |
AR之后可能会对此有所帮助
http://www.xilinx.com/support/answers/42557.html 谢谢你的文件。 --Krishna 以上来自于谷歌翻译 以下为原文 Following AR might have been helpful here http://www.xilinx.com/support/answers/42557.html Thanks for the doc. --Krishna |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3436 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-12 08:58 , Processed in 0.627669 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
555
