扫一扫,分享给好友
大家晚上好,
请问有人告诉我,是USB协议的各种USB程序员(MixPrim3,Fx2LP等)记录在任何地方?也就是说,有一个文档我可以用来开发我自己的PSoC程序员兼容程序员吗? AN73054描述并向PSoC3LP和PSoC5LP目标设备的PSoC5LP HSSP程序员提供源代码,但该应用注意事项不是基于PSoC5LP的基于USB的程序员;它没有出现在应用程序注释中提供的代码可以用来创建程序员。它可以被PSoC程序员用来编程PSoC3和PSoC5LP设备。 以上来自于百度翻译 以下为原文 Good evening, everyone, Can someone tell me please, is the USB protocol for the various USB programmers (miniprog3, FX2LP, etc.) documented anywhere? i.e. is there a document I can use to develop my own PSoC Programmer-compatible programmers? AN73054 describes and provides the source code to an PSoC5LP HSSP programmer for PSoC3 and PSoC5LP target devices, but this application note is not for a USB based programmer based on the PSoC5LP; it does not appear that the code provided in this application note can be used to create a programmer which is able to be used by PSoC Programmer to program PSoC3 and PSoC5LP devices. |
5个回答
HTTP://www. CyPress?COM/?RID=38154微型机器人3
HTTP://www. CyPress?COM/?RID=2543 PSoC程序设计 问候,Dana。 以上来自于百度翻译 以下为原文 http://www.cypress.com/?rID=38154 Miniprog 3 http://www.cypress.com/?rID=2543 PSOC Programming Regards, Dana. |
这些都是优秀的资源,Dana,但我相信他们是不够的。
我找的是口语在PC和FX2LP,miniprog3 PSoC编程软件之间的USB协议,PSoC 4先锋,等。这样我就可以实现自己的程序员能够与程序员为PSoC交流闪光装置。除非我误解你所提供的资料,他们没有提供USB接口的细节。他们都描述了如何一个程序员和编程设备之间进行通信。 同样,HSSP应用笔记没有解释具体端点配置和数据传输的PC和程序员之间的协议;他们解释程序和可编程器件之间的SWD协议。 以上来自于百度翻译 以下为原文 Those are exellent resources, Dana, but I believe they are insufficient. I am looking for the USB protocol that is spoken between the PSoC Programmer software on the PC and the FX2LP, MiniProg3, PSoC 4 Pioneer, etc.. so that I can implement my own programmer which can communicate with PSoC Programmer in order to flash the devices. Unless I am misreading the documentation you provided, none of them provide the USB interface details. They all describe how to communicate between a programmer and device to be programmed. Similarly, the HSSP application notes do not explain the specific endpoint configuration and data transfer protocol between the PC and the programmer; they explain the SWD protocol between the programmer and device to be programmed. |
这是一个内部协议,并没有在任何地方被记录。但是你总是可以在PC端编写你自己的程序员,因为它只需要把数据传送给你自己的程序员(然后再使用公共协议来编程PSoC)。
以上来自于百度翻译 以下为原文 AFAIK this is an internal protocol, and is not documented anywhere. But you can always write your own programmer on the PC side, since it just need to transfer the data to your own programmer (which then in turn uses the public protocol to program the PSoC). |
我想我听说CyPress在签署NDA时放弃了PrimoLL软件,并且有很好的理由来制造一个程序员等等。
最好是通过创建一个“MyCase'来联系CyPress”(在这个页面顶部的“支持和社区”-gt;”技术支持“-gt;”创建一个MyCase] 鲍勃 以上来自于百度翻译 以下为原文 I think I have heard that Cypress is giving away the protocoll software when you sign an NDA and have good reasons as manufacturing a programmer etc. Best would be to contact Cypress by creating a "MyCase" (At top of this page "Support&Community"->"Technical Support"->"Create a MyCase") Bob |
我猜它是主要有人建造的一个程序员,不能正常工作与psocprogrammer他们不得不应付所有支持电话本的原因。
以上来自于百度翻译 以下为原文 I'm guessing it's mainly having anyone build a programmer that won't work properly with psocprogrammer and they having to deal with all the support calls this causes. |
只有小组成员才能发言,加入小组>>
718个成员聚集在这个小组
加入小组1909 浏览 1 评论
1663 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
205浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
336浏览 2评论
363浏览 1评论
73浏览 1评论
GMT+8, 2024-5-8 22:31 , Processed in 0.734611 second(s), Total 56, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
