电子发烧友论坛|
大家好
我正在使用ST25R3911B制作RF阅读器。 通讯距离应大于50厘米。如果没有外接功率放大器,请告诉我。 #st25r3911b 以上来自于谷歌翻译 以下为原文 Hi all I am making RF reader using ST25R3911B. Communication distance should be more than 50cm.Please let me know if is possible without an external power amp. #st25r3911b |
1个回答
亲爱的朱莱夫,
通信距离非常依赖于阅读器和标签。 只有当读卡器与标签之间存在良好的耦合时,才能保证良好的通信距离。这也将确保标签具有良好的LMA(负载调制幅度)。如果标签天线的尺寸与读取器天线相似,则给出良好的耦合。通常读卡器天线有点大。 使用的协议也会影响通信范围。例如,ISO15693允许比ISO14443 A或B更大的距离。根据经验,通信距离大约是方形天线的长度。这意味着如果你有一个10厘米×10厘米的天线,使用如上所述的标签,通信距离也应该至少为10厘米。此外,您的读者的Q因素在这里发挥作用。 Q因子越高,LC天线槽中的功率就会越大,并且越难以符合ISO标准,甚至产生可解码的波形。 达到50厘米后,您需要相应地升级标签和阅读器的天线尺寸。 另一种方法是增加额外的放大器电路,以提高1.4W以上的输出功率,并为RFI接收器路径增加额外的滤波。 BR Travis 以上来自于谷歌翻译 以下为原文 Dear Zhulev, The communication distance depends very much on both - reader and tag. Only if there is a good coupling from reader to tag a good communication distance is guaranteed. This will also ensure that the tag has a good LMA (Load Modulation Amplitude). A good coupling is given, if the tag antenna is similar size than the reader antenna. Usually the reader antenna is a bit bigger. Also the used protocol will have an influence on the communication range. ISO15693 for example will allow bigger distances than ISO14443 A or B. A rule of thumb says that the communication distance is approximately the length of a square antenna. Which means if you have a 10cm times 10cm antenna the communication distance should also be at least 10cm using a tag as described above. Also the Q-Factor of your reader plays a role here. The higher the Q-Factor will be, the more power will resonate in the LC antenna tank and the harder it will be to be ISO compliant or even produce decode-able wave shapes. Achieving 50cm you will then need to upscale the antenna sizes for tag and reader accordingly. An alternative would be to add additional amplifier circuit to boost output power beyond the 1.4W and add additional filtering to the RFI receiver path. BR Travis |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1470 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1522 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3670 浏览 1 评论
3861 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2479 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
750浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
682浏览 5评论
729浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
973浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
777浏览 5评论
/9
GMT+8, 2025-12-13 05:36 , Processed in 0.678301 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
486
