电子发烧友论坛|
我通过GPIB使用labview控制6634B电源,并且有时会收到错误-141(无效字符数据),导致我的电源进入保护模式。
有谁知道这个错误意味着什么? 可能导致它的任何想法? 谢谢! 以上来自于谷歌翻译 以下为原文 I am controlling a 6634B power supply with LabView via GPIB and on a few occasions have received error -141 (Invalid Character Data) causing my power supply to go into protect mode. Does anyone know what this error means? Any ideas what may be causing it? Thanks! |
2个回答
什么会导致电源进入过电压/过电流条件以外的保护模式?
以上来自于谷歌翻译 以下为原文 What would cause the power supply to go into protect mode other than over voltage/ over current conditions? |
嗨,我想知道错误-141无效字符数据错误是由您发送的任何特定命令引起的?
或者你是否可以向仪器发送任何命令,它会产生错误?我认为有几种方法可以解决这个问题。 首先,您必须查看它是Labview错误还是仪器错误。 无论您使用哪种I / O驱动程序/库,都应该有一个简单的脚本工具,允许您通过接口逐个发送SCPI命令。 您可以先尝试此操作,看看它是否仍然会生成错误。 如果这里的一切都很好,那么我们就知道它与NI程序有关。过电压和过电流是两种最典型的保护。 还有其他的东西,如温度过高。 发生保护后,如果按前面板上的“PROT”键,显示屏会显示跳闸的保护吗?Steven LeeAgilent Sales Support 以上来自于谷歌翻译 以下为原文 Hi, I was wondering if the Error -141 Invalid Character Data error is caused by any particular command that you are sending over? Or is it the case that you can send any command to the instrument and it will generate the error? I think there are a few ways to tackle this. First, you have to see whether it is a Labview error or an instrument error. Whatever I/O driver/library you are using should have a simple scripting tool that allows you to send SCPI commands one by one over the interface. You can try this first and see whether it still generates the error. If everything is good here, then we know it has to do with the NI program. Overvoltage and Overcurrent are the two most typical protection that occurs. There are other things like over temperature. After the protection occurs, if you press the "PROT" key on the front panels, does the display show you what protection tripped? Steven Lee Agilent Sales Support |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:38 , Processed in 4.258064 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3492
