keil中的u*** demo Audio_Speaker 的u***_istr.c文件,其中包含一个void USB_Istr(void)函数用于处理所有u***宏单元中断
void USB_Istr(void) { wIstr = _GetiSTR(); #if (IMR_MSK & ISTR_RESET) if (wIstr & ISTR_RESET & wInterrupt_Mask) { _SetISTR((u16)CLR_RESET); Device_Property.Reset(); #ifdef RESET_CALLBACK RESET_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_DOVR) if (wIstr & ISTR_DOVR & wInterrupt_Mask) { _SetISTR((u16)CLR_DOVR); #ifdef DOVR_CALLBACK DOVR_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_ERR) if (wIstr & ISTR_ERR & wInterrupt_Mask) { _SetISTR((u16)CLR_ERR); #ifdef ERR_CALLBACK ERR_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_WKUP) if (wIstr & ISTR_WKUP & wInterrupt_Mask) { _SetISTR((u16)CLR_WKUP); Resume(RESUME_EXTERNAL); #ifdef WKUP_CALLBACK WKUP_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_SUSP) if (wIstr & ISTR_SUSP & wInterrupt_Mask) { /* check if SUSPEND is possible */ if (fSuspendEnabled) { Suspend(); } else { /* if not possible then resume after xx ms */ Resume(RESUME_LATER); } /* clear of the ISTR bit must be done after setting of CNTR_FSUSP */ _SetISTR((u16)CLR_SUSP); #ifdef SUSP_CALLBACK SUSP_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_SOF) if (wIstr & ISTR_SOF & wInterrupt_Mask) { _SetISTR((u16)CLR_SOF); bIntPackSOF++; #ifdef SOF_CALLBACK SOF_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_ESOF) if (wIstr & ISTR_ESOF & wInterrupt_Mask) { _SetISTR((u16)CLR_ESOF); /* resume handling timing is made with ESOFs */ Resume(RESUME_ESOF); /* request without change of the machine state */ #ifdef ESOF_CALLBACK ESOF_Callback(); #endif } #endif /*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*/ #if (IMR_MSK & ISTR_CTR) if (wIstr & ISTR_CTR & wInterrupt_Mask) { /* servicing of the endpoint correct transfer interrupt */ /* clear of the CTR flag into the sub */ CTR_LP(); #ifdef CTR_CALLBACK CTR_Callback(); #endif } #endif } 其中红色部分为函数对CTRM中断的处理,调用了函数CTR_LP()。 但是同步传输是双缓存,对应的不应该是高优先级中断,那这里不是应该调用CTR_HP()吗, |
相关推荐 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
555 浏览 0 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
449 浏览 1 评论
293 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
257 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
624 浏览 2 评论
1391浏览 9评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
87浏览 3评论
45浏览 3评论
STM32CUBEMX4.22.1在main函数里面添加一行语句就死机的原因?
58浏览 3评论
51浏览 3评论
GMT+8, 2024-5-6 02:33 , Processed in 0.770497 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
