电子发烧友论坛|
嗨,
IBIS型号不适用于此部件号。 L9663-1 我在哪里可以找到IBIS模型? 我可以使用这个部件号的I / O型号吗? 感谢致敬 Arunkumar K. #l9663-1 以上来自于谷歌翻译 以下为原文 Hi, IBIS model not available for this part number . L9663-1 Where can i find the IBIS model ? Is there any I/O model i can use for this part number? Thanks and Regards Arunkumar K #l9663-1 |
3个回答
嗨,阿伦,
L9663不是STM32 MCU,因此在“STM32 MCU论坛”中找不到方便的答案。 我已将您的问题转移到“模拟和音频”空间,有人可能会帮助您。 最好的祝福, Khouloud。 以上来自于谷歌翻译 以下为原文 Hi Arun, The L9663 is not an STM32 MCU, thus you will not find a convenient answer in the 'STM32 MCUs Forum'. I have moved your question to 'Analog and Audio' space where someone may assist you. Best regards, Khouloud. |
你好阿伦,
L9663是一款汽车PSI5收发器。我询问了分部,很遗憾我们没有这个产品的IBIS模型。我们能为您做些什么吗? 问候。 埃琳娜 以上来自于谷歌翻译 以下为原文 Hello Arun, L9663 is an Automotive PSI5 transceiver. I have enquired with division and unfortunately we don't have IBIS models for this product. Is there something else we can do for you? regards. Elena |
外围传感器接口(PSI5)是汽车传感器应用的接口。 PSI5是基于现有外围传感器传感器接口的开放标准,为多种传感器应用提供通用且灵活的解决方案。
PSI5接口允许异步或同步操作以及不同的总线模式。该设备兼容v1.3和v2.1 PSI5版本(本文档中指定了限制)。它具有多种传感器电源电流和可变数据字长(8至28位)。 传感器使用相同的线路连接到ECU,用于电源和数据传输。收发器IC为传感器提供预调节电压,并读取传输的传感器数据。 PSI5接口允许点对点连接或总线模式。 https://essayacademia.com的帮助 帮助学生了解每篇自定义书面论文的基础知识,以及创意写作的要素。 以上来自于谷歌翻译 以下为原文 The Peripheral Sensor Interface (PSI5) is an interface for automotive sensor applications. PSI5 is an open standard based on existing sensor interfaces for peripheral sensors and offers a universal and flexible solution for multiple sensor applications. The PSI5 interface allows asynchronous or synchronous operations and different bus modes. The device is compatible with both v1.3 and v2.1 PSI5 revisions (limitations are specified inside this document). It operates with a wide range of sensor supply current and variable data word length (8 to 28 bit). The sensors are connected to the ECU using the same line for power supply and data transmission. The transceiver IC provides a pre-regulated voltage to the sensors and reads in the transmitted sensor data. The PSI5 interface allows either point to point connection or bussed mode. The assistance of https://essayacademia.com helps students understand the basics of every custom written paper, as well as the elements of creative writing. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
749浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
681浏览 5评论
728浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
969浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
773浏览 5评论
/9
GMT+8, 2025-12-12 06:35 , Processed in 1.259392 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
612
