电子发烧友论坛|
你好!我有以下问题使用SPI引导与USB回退:每当重置(或上电)发生时,固件从SPI闪存加载。到目前为止,这还不错。现在,我正在寻找一种方法,将一个不同的固件加载到RAM中(在闪存之前测试一个新的版本),之后b)重写闪存。对于这两个,我需要在FX3中存在特殊的引导加载程序。我怎样才能达到这个“系统”,即纯粹的SW驱动?(我将无法在我自己的未来HW中改变PMODE引脚,所以这是没有选择的)。一种很难的方法可能会在改变某些东西之前使Flash无效,但我不喜欢这样做,只是为了测试替代的基于RAM的版本。当做
以上来自于百度翻译 以下为原文 Hello! I've got the following issue using SPI-Boot with USB-Fallback: Whenever a reset (or power-up) occurs, The firmware is loaded from the SPI flash. So far, this works quite OK. Now I'm looking for a method to a) load a different firmware to the RAM (test of a new release before flashing) and later b) overwriting the flash. For both, I need special bootloaders present in FX3. How am I able to to this "in system", i.e. purely SW driven? (I will not be able to just change the PMODE pins in my own future HW, so this is no option). A hard way would probably be invalidating the flash before changing something, but I don't like to do this just to test with alternative RAM-based versions. Regards |
2个回答
你好,卡列夫!谢谢你的链接。但是,这个例子不再出现在下拉框中了。同时,我实现了“CyoBoTrace.img”的解决方案,以及SPI闪存/冷重置的先前失效。到目前为止运行良好,但是在Flash编程之后需要一个电源周期是不受欢迎的。通过查看“CyootToCaler .img”和Bootloader的源代码将有助于获得洞察力。知道我在哪里可以进入吗?此外,这两个图像中的0xA0供应商请求功能的MouthPage链接(以及如何从主机地址)将是有益的。问候,彼得
以上来自于百度翻译 以下为原文 Hello Kalev! Thanks for the link. However, the example is not present in the drop box any more... Meantime, I realized a solution with "CyBootProgrammer.img" and prior invalidation of SPI flash / use of cold reset. Works fine so far, however the need for a power cycle after flash programming is not welcome. It would be very helpful to gain insight by looking at the source code of "CyBootProgrammer.img" and the BootLoader. Any idea where I can get access to? Further more a link to man page of the ominous 0xA0 vendor request functionality in these two images (and how to address from host) would be helpful. Regards, Peter |
你好,
引导加载程序示例项目位于赛普里斯…固件BooToFFW目录。 此外,FX3 API源可能是有用的。这些是在 HTTP://www. CyPress?COM/?RID=57990 FX3固件源,1.3.1版 Br 卡列夫 以上来自于百度翻译 以下为原文 Hi, Boot loader example project is in Cypress ...firmwareboot_fw directory. Also, FX3 API sources might be useful. These are available at http://www.cypress.com/?rID=57990 FX3 firmware sources, version 1.3.1 br, kalev |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 14:44 , Processed in 0.709423 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8125
