如何修复?
安装程序不提供任何关于问题性质的提示。 以上来自于百度翻译 以下为原文 how to fix it ? the installer does not give any hint about the nature of problem.. |
9个回答
谢谢Dana,我会努力的。
发行说明是一个很好的起点。可能是Net Framework 2 SP 2丢失 以上来自于百度翻译 以下为原文 Thanks Dana, will try. Release notes is a good starting point. Maybe NET Framework 2.0 SP 2 missing |
一种可能的方法是:安装程序在一点上提取所有单独的安装程序(每个工具文档一个等等)到临时目录。您可能会尝试将它们复制到一个单独的位置,并逐个安装它们。
另一个问题:你从哪里得到安装程序?是从CDOR下载的吗?在后一种情况下,尝试重新下载它,也许它刚刚被破坏了。 以上来自于百度翻译 以下为原文 One possible way forward: the installer extracts at one point all the seperate installers (one for each tool documenation and so on) to the temp directory. You might try to copy them to a separate location, and install them one by one. Another question: where did you get the installer from? Is it from CD or downloaded? In the latter case - try redownloading it, maybe it just got corrupted. |
谢谢。
好点。 下载软件。 不幸的是,安装程序删除所有的文件后,错误检测。 我不能确定任何包含有意义的/可执行文件下载和安装遗留的临时目录。 更多提示? 以上来自于百度翻译 以下为原文 Thanks HLI. Good point. Software was downloaded. Unfortunately, the installer deletes all files after errors detected. I cannot identify any temp directory containing meaningful/executable files downloaded and left over by the installer. More hints ? |
如果你提出一个案子,我相信他们会与你合作。
远程桌面连接以帮助安装。 提交一个技术案例 CyPress网站 “支持” “技术支持” “创建一个MyCase'” 你必须在网站上注册才能提交案件。 问候,Dana 以上来自于百度翻译 以下为原文 If you file a CASE I believe they will work with you over a remote desktop connection to help with the install. To file a tech case - www.cypress.com “Support” “Technical Support” “Create a MyCase” You have to be registered on the site to file the CASE. Regards, Dana |
错误消息显示临时目录(在Win 7下的%PrruleDeR/AppDATa/Studio/Timp)下。我看这些文件时所做的是在运行安装程序之前清理临时目录。这样,安装程序创建的新文件夹立即弹出。在我的情况下,我有一个错误信息,我需要承认,并能够复制文件之前。也许你只需要足够快…
(安装过程中的哪一点出错?我看到在启动窗口提取…',和提取的安装程序创建得到有。完成后,安装掩护向导打开。 以上来自于百度翻译 以下为原文 The error messages show the temporary directory (under Win7 its in %PROFILEDIR/AppData/Local/temp). What I did when I looked at these files was to clean the temp directory before running the installer. That way, the new folder created by the installer pops up immediately. In my case I had an error message I needed to acknowledge, and was able to copy the files before that. Maybe you just need to be fast enough... (At which point in the install process do you get the error? I see right at the start a window 'Extracting ...', and the extracted installers get created there. When that is finished, the Installshield wizard opens.) |
提取的文件只是MSI安装程序包,所以你可以只安装双击。这个执行比普通安装少一点逻辑(其中,例如,尝试做一些缓存通常是无用的)。
通过时间的临时文件夹排序,所以你的文件已经提取的硒。一旦复制过程中涉及的一种,安装程序无法删除它。但是,如果删除会自动在错误对话框弹出UZP,它可能需要多次尝试复制的一切。 以上来自于百度翻译 以下为原文 The extracted files are just MSI installer bundles, so you can them just install by double-click. Thsi executes a little bit less logic than the normal installer (which, for example, tries to do some caching which is normally useless). Sort the temporary folder by time, so you se which files are already extracted. Once the copy process touches onew, the installer should not be able to delete it. But if the delete happens automatically even before the error dialog pops uzp, it might take several tries to copy everything. |
当您接收到新的PSoC4原型工具包时,您肯定会使用Bootloader。当您使用MIXPROP3或当您拥有PSoC5开发工具包时,需要使用该桥控制器。
鲍勃 以上来自于百度翻译 以下为原文 When you receive the new PSoC4 prototyping kit you'll certainly use the bootloader. The bridge controller is afaik needed when you use the MiniProg3 or when you have got a PSoC5 development kit. Bob |
从这个“手动安装的IDE,PSoC Creator时,或任何其他的安装程序,甚至文档,停止
“XY已检测到一个问题,必须停止..通知微软..” : 以上来自于百度翻译 以下为原文 when starting this 'manually installed' IDE, psoc creator, or any other intalled program, even documentation, stops with 'xy has detected a probem and must be stopped..inform Microsoft..' :-( |
提交一个技术案例。在这个窗口的顶部,在支持和社区&技术支持下。
鲍勃 以上来自于百度翻译 以下为原文 File a technical MyCase. At top of this window under Support&Community -> Technical support -> Create a MyCase Bob |
只有小组成员才能发言,加入小组>>
747个成员聚集在这个小组
加入小组2046 浏览 1 评论
1794 浏览 1 评论
3604 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1729 浏览 6 评论
1489 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
450浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
316浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
387浏览 2评论
332浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
546浏览 2评论
GMT+8, 2024-10-22 02:30 , Processed in 1.081911 second(s), Total 94, Slave 77 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
