电子发烧友论坛|
你好。
我试图通过SAI输出24khz单声道pcm数据到wm8994编解码器。 16khz mono似乎工作正常,但默认情况下ST不支持24。我对codec和sai init的支持做了一些改动。现在我想知道还有什么需要改变。 作为基线,我让时钟配置器使用与48khz(44 vs 48 khz域)相同的时钟路径。来自sai透视图的插槽号和立体声模式也在SAI init中处理: if(channels == 1){ haudio_out_sai.Init.MonoStereoMode = SAI_MONOMODE; haudio_out_sai.Slotinit.SlotNumber = 2; } else { haudio_out_sai.Init.MonoStereoMode = SAI_STEREOMODE; haudio_out_sai.SlotInit.SlotNumber = 4; 在wm8994.c中 - > init函数我根据cirrius wm8994规范(v.4.5)将24khz选择添加到输出路径。 案例AUDIO_FREQUENCY_24K: / * AIF1采样率= 24.000(KHz),比率= 256 * / counter + = CODEC_IO_Write(DeviceAddr,0x210,0x0053); break; CubeMX不提供将SAI配置为24khz模式的选项。是否有一些限制或者这只是被遗漏了?在启用24Khz模式时还有其他我应该考虑的事项吗? #STM32f769i迪斯科-AUDIO-WM8994 以上来自于谷歌翻译 以下为原文 Hi. I'm trying to output 24khz mono pcm data over SAI to wm8994 codec. 16khz mono seems to work OK, but 24 is not supported by ST by default. I've made some changes for the support to codec and sai init. Now I wonder what else needs to be changed. As baseline I've let the clock configurators use same clock paths as 48khz (44 vs 48 khz domains). Slot number and stereo mode from sai perspective is also handled in SAI init: if (channels == 1) { haudio_out_sai.Init.MonoStereoMode = SAI_MONOMODE; haudio_out_sai.SlotInit.SlotNumber = 2; }else { haudio_out_sai.Init.MonoStereoMode = SAI_STEREOMODE; haudio_out_sai.SlotInit.SlotNumber = 4; }in wm8994.c -> init function I added 24khz selection to output path according to cirrius wm8994 spec (v.4.5). case AUDIO_FREQUENCY_24K: /* AIF1 Sample Rate = 24.000 (KHz), ratio=256 */ counter += CODEC_IO_Write(DeviceAddr, 0x210, 0x0053); break;CubeMX doesn't give the option to configure the SAI into 24khz mode. Is there some limitation or is this just left out? is there any other things I should consider when enabling the 24Khz mode? #stm32f769i-disco-audio-wm8994 |
1个回答
好的,改变是可以的,并与24khz wav一起使用。
问题是我的mp3解码。它似乎有很多失真。 以上来自于谷歌翻译 以下为原文 Ok, the changes were OK and works with 24khz wav. Problem is my mp3 decoding. It seems to have lot of distortion. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 09:53 , Processed in 0.706666 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1754
