电子发烧友论坛|
以下是关于AN5439关于外部晶体振荡器的摘录:
如果没有使用MHz或KHz ECO,ECO引脚上的外部时钟信号可以使用KHz或MHz的晶体输入引脚将外部时钟信号路由到ECO时钟网络上。这允许使用这些时钟网络代替时钟树中通常的DSI时钟网络。外部时钟可以通过KHz和MHz XTALIN引脚路由到该部分。XTALOUT引脚应该允许浮动。理想情况下,外部信号应该是轨到轨正弦或方波。如果信号的幅度太低,则它们不能被正确地翻译成数字信号。这些信号必须在ECOS的额定频率,在32.768 kHz或4-25兆赫。外部时钟也可以到部分使用GPIO路由。详情见an60631 PSoC 3和PSoC -®5lp时钟资源。 我想用MEMS振荡器为MHz的32kHz生态和生态。这听起来像我可以配合他们每个生态输入正确,但它不说我需要设置的创造者。它具有所有微调晶体如故障恢复,参数调整的幅度,并参考水平。有人知道我在这种情况下会用到什么设置吗?同时,它说它应该是轨到轨输入,但铁路是我们在谈论什么?我打算用5V只有一个或两个端口,但MEMS振荡器似乎是3.3V的最大多数时间。似乎为港口生态VDDIO引脚都不会有任何的影响由于引脚被用在一个不同的方式,对吗?我们将不胜感激。 以上来自于百度翻译 以下为原文 Here's an excerpt from AN54439 about external crystal oscillators: Using an External Clock Signal on the ECO Pins If the MHz or kHz ECO is not being used, an external clock signal may be routed onto the ECO clock nets using the kHz or MHz crystal input pins. This allows the use of these clock nets in place of the usual DSI clock net in the clock tree. External clocks can be routed into the part through the kHz and MHz XtalIn pins. The XtalOut pins should be allowed to float. Ideally, the external signals should be rail-to-rail sine or square waves. If the amplitude of the signals is too low, they may not be properly translated into digital signals. These signals must be within the frequency ratings of the ECOs, either at 32.768 kHz or 4-25 MHz. External clocks can also be routed into the part using the GPIOs. For more details, see AN60631 - PSoC® 3 and PSoC 5LP Clocking Resources. I want to use MEMS oscillators for both the MHz ECO and the 32khz ECO. It sounds like I can tie them right to the input of each ECO, but it doesn't say anything about how I would need to set it up in Creator. It has all the parameters for fine tuning the crystal such as fault recovery, amplitude adjustment, and reference levels. Anyone know what settings I would use in this case? Also, it says it should be a rail to rail input, but which rail are we talking about? I'm planning on using 5V for all but one or two ports, but the MEMS oscillators seem to be 3.3V max most of the time. It seems like the VDDIO for the port where the ECO pins are located would not have any effect since the pin is being used in a different mode, right? Some guidance would be greatly appreciated. |
8个回答
ECOS是需要外部晶体的振荡器电路。这就是配置的目的。你的MEMS振荡器是一个独立的组件。因此,您需要配置PSoC,只需使用外部时钟信号。我知道它有可能兆赫生态,但我不是那么肯定的KHz生态(我没有时间现在检查)。只要看看时钟配置屏幕…
以上来自于百度翻译 以下为原文 The ECOs are oscillator circuits needing an external crystal. Thats what the configuration is for. Your MEMS oscillators are an standalone component. So you need to configure PSoC for just using an external clock signal. I know that its possible for the MHz ECO, but I'm not so sure about the kHz ECO (and I lack the time now to check). Just look in the clock configuration screen... |
您可以直接联系MAX(AP注释的作者),并在这里发布
其余的论坛。 Max k@ CyPress AP注释没有讨论ECO AMP是标准的逻辑逆变器还是特定的AMP。 设计,所以一个懒惰的R R问题(我猜是VSSD到VDDD)会是这样的 猜测,不应该被认为是足够的。 你可以建议马克斯Rev他的AP笔记包括你问的基本问题。 问候,Dana。 以上来自于百度翻译 以下为原文 You might contact max (author of ap notes) directly, and post back here for the rest of the forum. maxk@cypress.com Neither ap note discusses if ECO amp is a standard logic inverter or a specific amp design, so anwering R-R question (my guess is Vssd to Vddd) would be just that, a guess, and should not be considered sufficient. You might suggest max rev his ap note(s) to include the basic questions you are asking. Regards, Dana. |
更深入地阐述:
时钟配置只允许为IMO馈送外部时钟,但不针对ILO,外部时钟信号通过DSI(数字信号互连)路由,因此它是一个正常的外部信号,意味着外部振荡器需要提供逻辑电平信号(CMOS或TTL)I。T可以将振荡器连接到振荡器的XI输入端,而XO管脚打开应该工作,但是TRM没有说什么(虽然AN51439确实)输入信号仍然受最大额定值(当不使用时,它们是正常的GPIOs,所以输入ValTAG)。E应该在0V - Vdd),我想用数字信号工作最好。 以上来自于百度翻译 以下为原文 To elaborate a little bit deeper:
对于32千赫,你将通过内部路由到
放大器设计的振荡,如果它不是一个标准的CMOS反相器 喜欢用GPIO结构,其水平偏差可能需要解决的问题, 需要用Max来确认。 我会发邮件给Max和点他这个帖子,看看我们得到什么。 问候,Dana。 以上来自于百度翻译 以下为原文 For the 32 Khz, you will be coming thru the internal route to the amp designed for oscillation, if its not a standard CMOS inverter like used in GPIO structures, its levels/bias may need to be addressed, need to be confirmed with max. I will email max and point him to this thread, and see what we get. Regards, Dana. |
我还没听到Max的任何消息,我要去创建一个支持案例。
以上来自于百度翻译 以下为原文 I haven't heard anything from Max. I'll go create a support case. |
我也没听说过,很高兴你张贴了一个案子,也许我应该这样做。
GETGO因为我们永远不知道作者是否仍然与公司在一起。 问候,Dana。 以上来自于百度翻译 以下为原文 I have not heard either, glad you posted a CASE, maybe I should have done that from the getgo as we never know if author still with company. Regards, Dana. |
这是我的反应。看起来,我很高兴去。
兆赫XTAL引脚也是GPIOS。因此,它们可以用作正常GPIOs。禁用CyDWR& GT时钟树中的ECO,并选择数字信号,并从数字时钟中导出其他时钟。程序与AN60631相同。如果MEMS振荡器的峰-峰值振幅为3.3 V或更大,则它应该工作,因为内部信号进入时钟树,其中电平移位将其降低到1.8 V峰到峰值。对于KHz生态,你需要在时钟树中启用KHz生态,只需将外部MEMS振荡器连接到KHz生态输入。在创建者中不需要设置。因此,总结是MHC-ECO需要禁用,相同的输入引脚可以用来提供外部数字时钟。但KHz生态需要启用,并连接外部时钟的输入引脚KHz生态在PSoC。我测试了两钟INT上述配置和发现这是工作。 以上来自于百度翻译 以下为原文 Here's the response to my case. Looks like, I'm good to go. MHz XTAL pins are also GPIOs. Hence they can be used as normal GPIOs. Disable the ECO in the .cydwr -> clock tree and select the Digital Signal and source the other clocks from Digital clock. The procedure is same as in the AN60631. If the peak to peak amplitude of the MEMS oscillator is 3.3 V or more, it should work because internally the signal gets into the clock tree where a level shift will reduced it to 1.8 V peak to peak. For KHz ECO, you need to enable the KHZ ECO in the clock tree and just connect the external MEMS oscillator to the KHz ECO input. No setting is required for this in Creator. So summary is MHz ECO needs to be disabled and the same input pin can be used to give external digital clock. But KHz ECO needs to be enabled and connect external clock to the input pin of KHz ECO in PSoC. I tested both of the clocks int the above mentioned configuration and found it to be working. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 15:18 , Processed in 0.855864 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1086
