H,
我用CY8C3666 AXI-040设计了新的电路。由于错误,当试图安装程序芯片时无法找到。我遵循PSOC3电路设计的规则,但是找不到芯片。然后我寻找错误。我发现VDDD电压>VDDA电压。我测量了VDDD电压0.7 V VDDA电压为5.2 V,所以无法找到芯片。当我与跳线相等电压时。集成电路很快就被加热了。我找不到变暖的原因。我附上设计文件。你能看一下设计吗?当VDDD=VDDA时,IC的升温原因是什么?谢谢。 JOP1.PDF 634 K 以上来自于百度翻译 以下为原文 Hİ, I designed new circuit using CY8C3866AXI-040. Due to an error, when trying to install the program chip can not be found. I followed the rules of the circuit design psoc3 but chip can't be found. Then I searched for the error. I found that VDDD voltage> VDDA voltage. I measuered VDDD voltage 0.7 V. VDDA voltage is 5.2 V. So chip can't be found. When I equal to voltages with jumpers. IC quickly is heating. I could not find the cause of wARMing. I attach design file. Can you look at design. When VDDD = VDDA , what is the cause of warming of IC. Thanks. Job1.PDF 634.0 K |
2个回答
Hi-Y-LMAZ,我无法从图板和示意图中找出原因。我猜,有电压的引脚是接地的吗?我认为VDDD是可疑的。
以上来自于百度翻译 以下为原文 Hi yılmaz I can't figured out the cause of ploblem from picture of board and schematic. I guess, does some pins that has a voltage was grounded? Vddd is doubtful I think. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2101 浏览 1 评论
1848 浏览 1 评论
3666 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1783 浏览 6 评论
1533 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
564浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
418浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
434浏览 2评论
380浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
909浏览 2评论
GMT+8, 2024-12-21 13:48 , Processed in 0.816893 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
