电子发烧友论坛|
我试图动态地从FRC切换到外部8MHz时钟。我可以使用和谐时钟选择配置器,让我的系统在FRC+PLL或PRIMARYS+PLL上运行。我已经编写了代码来设置一个或另一个,但是我从来没有使PRIMARYS+PLL时钟工作。在函数运行之后,使用调试器在Nop()上中断,当我检查OSCON位时,COSC显示stet在0x01,即FRC。下面是代码:
以上来自于百度翻译 以下为原文 I am trying to switch from the FRC to an external 8 MHz clock dynamically. I can use the HARMony clock selection Configurator and get my system to run either on the FRC + PLL or the PRIMARYSYS+PLL fine. I have written code to now set one or the other but I never get the PRIMARYSYS+PLL clock to work. I used a debugger to break on a Nop() after the function runs and when I check the OSCON bits COSC show is stet at 0x01 which is the FRC. Any ideas? Here is the code: /*Use of "SYS_CLK_SystemClockSourceSwitch" to set clock dynamically. * */ // Stop DMA SYS_INT_SourceDisable(INT_SOURCE_DMA_0); SYS_INT_SourceDisable(INT_SOURCE_DMA_1); SYS_INT_SourceDisable(INT_SOURCE_DMA_2); SYS_INT_SourceDisable(INT_SOURCE_DMA_3); Nop(); //Save INCO, INC1 and INC2 value. Then Clear. SYS_INT_Disable(); Nop(); volatile int8_t clockSource ; // To catch the return from source switch. if (1){ // Arguments are clock source, PLLMULT, PLLODIV, and wait. clockSource = SYS_CLK_SystemClockSourceSwitch (SYS_CLK_SOURCE_FRC_SYSPLL, 18, 0, true ); } else { // Arguments are clock source, PLLMULT, PLLODIV, and wait. //clockSource = SYS_CLK_SystemClockSourceSwitch (SYS_CLK_SOURCE_PRIMARY_SYSPLL, clockSource = SYS_CLK_SystemClockSourceSwitch (3, 18, 0, true ); } //Restore INCO, INC1 and INC2 value. Then Clear. Nop(); SYS_INT_Enable(); Nop(); // Start DMA SYS_INT_SourceEnable(INT_SOURCE_DMA_0); SYS_INT_SourceEnable(INT_SOURCE_DMA_1); SYS_INT_SourceEnable(INT_SOURCE_DMA_2); SYS_INT_SourceEnable(INT_SOURCE_DMA_3); Nop(); //End of clock setup, switching. |
1个回答
你需要一个类似锁锁的DeFixION系统锁(DEVCONNIDID0),我认为有一个以上的解锁功能。
以上来自于百度翻译 以下为原文 do you need an unlock like PLIB_DEVCON_SystemUnlock(DEVCON_ID_0); I think there is more than one unlock function. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5795 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1126浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-3 13:57 , Processed in 0.884810 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2316
