电子发烧友论坛|
嗨,我能够用ICD3工具用MPLAB X IDE v3.35来编程我的dsPIC33EP128GP504设备,因为MPLAB X在最后会显示“编程/验证完成”,并且我的设备确实如我所预期的那样工作。但是,我根本不能从设备读回任何内存内容!我很困惑为什么会这样????我已经检查过“配置”设置,它们和我正在使用的其他设备完全相同,我能够如预期那样读回内容。(即,在我的项目中使用了两个dsPIC33EP128GP504设备。一个我可以读回内容,而另一个我不能,他们现在有完全相同的“配置”设置。)有人知道可能会发生什么吗????厘米
以上来自于百度翻译 以下为原文 Hi, I have been able to program my dsPIC33EP128GP504 device using the MPLAB X IDE v3.35, with the ICD3 tool, because MPLAB X would show 'Programming/Verify complete' at the end and my device does work as I expected. However, I have not been able to read back any memory contents from the device at all! I'm puzzled why does this happen??? I've checked the 'config' settings, and they are exactly identical to the other device I'm using which I have been able to read back the contents as expected. (I.e., I'm using two dsPIC33EP128GP504 devices in my project. One I can read back the contents, while the other I cannot, and they have exactly the same 'config' settings now.) Does anyone know what may be going on??? CM |
2个回答
这将有助于实际显示这些配置设置是什么。
以上来自于百度翻译 以下为原文 It would be helpful to actually show what these config settings are. |
读回的代码是否锁定在COFF设置中?不同的设备有不同的设置,在这种情况下,相同或不同并不意味着好或坏。你到底是什么意思?你收到错误信息了吗?错误的数据?全部0xFF?
以上来自于百度翻译 以下为原文 Is the code read back locked in the COFF settings? Different devices have different settings identical doesn't mean good or bad in this case. What exactly do you mean by you can't read back? are you getting an error message? the wrong data? all 0xFF? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:26 , Processed in 1.653429 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2182
