电子发烧友论坛|
您好,我已经成功地在PIC32 MX NVM读/写上工作了。现在我必须工作在SPIC33 EP32 MC202NVM读/写上。我需要保存4个整数值。DSPIC33 EP32 MC202的耐久性是多少?什么样的变化我需要工作的DSPIC33 EP(XC16编译器)..我可以使用相同的代码吗?有演示代码吗?我需要装配级指令来使用DSSPICEP吗?——TS9
以上来自于百度翻译 以下为原文 Hello, I have successfully worked on PIC32MX NVM Read/Write .Now I have to work on dsPIC33EP32MC202 NVM Read/Write. I need to save 4 integer values . What is the endurance for dsPIC33EP32MC202 ? What kind of changes I need to work the dsPIC33EP (XC16 Compiler).. Can I use same code ? Any Demo Code ? Do I Need assembly level instructions to Work with dsPIC33EP ? #include // Tell the compiler where you want it: #define ROMDATA1_ADDR 0x9d008000 #define NVM_PAGE_SIZE 4096 const uint16_t __attribute__ ((space(prog), address(ROMDATA1_ADDR))) RomData1[NVM_PAGE_SIZE]; // Let the compiler/linker put this anywhere it wants to const uint16_t __attribute__ ((space(prog), aligned(NVM_PAGE_SIZE))) RomData2[NVM_PAGE_SIZE]; void TestNVM(void) { unsigned int x,databuff[10]={'A','B','C','D'}; // Note that for xc32 and c18, just initializing Uart2 makes // printf work. // Erase second page of Program Flash NVMErasePage((void *)ROMDATA1_ADDR); // Write 128 words starting at Row Address NVM_PROGRAM_PAGE printf("Write Value n"); NVMWriteRow((void *)ROMDATA1_ADDR, (void*)databuff); printf("Display Written Valuen"); printf((void *)ROMDATA1_ADDR) ; printf((void *)ROMDATA1_ADDR+4) ; printf((void *)ROMDATA1_ADDR+8) ; printf((void *)ROMDATA1_ADDR+12) ; printf("nn"); } -- TS9 |
3个回答
您好,我从Microchip网站上已经有了CykDeCe88yRTSPWorddWrad示例。在研究了这个演示后,我想使用DSPICTSPAPI API和RTSPAPI API来使用DSPIC33 EP设备NVM来使用。/ /读取页面并将数据放入Page MeReRoBuf数组TEMP= Flash Page Read(NVMADRU,NVMADRPGEAR,Page)//修改Page MeReRoBuf数组TEMP= Flash Page MyDyFy(NVMROW,NVMSIZE,MyRoDATAILAM,Page Error BuffFF);/ /在Flash TEMP= Flash Page(NVMADRU,NVMADRPage对齐)中擦除页面;/ /用修改数据TEMP= Flash Page编写程序(NVMADRU,NVMADRPGEAR对齐,Page MeReBufff)无法理解如下:如何选择DSPIC33 EP32 MC202中的特定记忆?下面的PIC32 MXDSPIC33 EP如下?请更新我……TS9
以上来自于百度翻译 以下为原文 Hi, I have checked ce478_rtsp_word_write example from Microchip website.After study this demo I think rtsp_api.h and rtsp_api.s is necessary to work with dsPIC33EP Devices NVM to use . // Read the page and place the data into pageMirrorBuf array temp = FlashPageRead( nvmAdru, nvmAdrPageAligned, pageMirrorBuff ); // Modify the pageMirrorBuf array temp = FlashPageModify( nvmRow, nvmSize, myRowDataInRam, pageMirrorBuff ); // Erase the page in Flash temp = FlashPageErase( nvmAdru, nvmAdrPageAligned ); // Program the page with modified data temp = FlashPageWrite( nvmAdru, nvmAdrPageAligned, pageMirrorBuff ); Unable to understood as below: nvmAdru = __builtin_tblpage( &myRowData1InFlash[0] ); nvmAdr = __builtin_tbloffset( &myRowData1InFlash[0] ); nvmAdrPageAligned = nvmAdr & 0xF800; // Get the Flash Page Aligned address nvmRow = ( (nvmAdr >> 7) & 7 ); // Row in the page nvmSize = 128; nvmOffset = 8; How to chose specific memory in dsPIC33EP32MC202 ? As below for PIC32MX #define ROMDATA1_ADDR 0x9d008000 #define NVM_PAGE_SIZE 4096 const uint16_t __attribute__ ((space(prog), address(ROMDATA1_ADDR))) RomData1[NVM_PAGE_SIZE]; dsPIC33EP is like below ? uint16_t myRowData1InFlash[] __attribute__( (space(prog), address(0x1000)) ) ={......} // Long Array Please update me .. -- TS9 |
我使用的是频率为7.37兆赫的内部振荡器。是否需要为NSPM设置任何配置来使用DSSPICEP32 MC202?
以上来自于百度翻译 以下为原文 I am using Internal Oscillator Of Frequency 7.37 MHz. Do I need to set Any configuration for using NVM for dsPIC33EP32MC202 ? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 20:36 , Processed in 0.765345 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1732
