你好,
我们需要使用HVLED001A设计一个LED驱动器,以提供100w和150w的LED串。根据数据表,我们需要有两个阶段来提供这种功率,但在eDesignSuite中我们还没有找到办法。 有没有办法使用eDesignSuite计算我的驱动器100W和150w两个阶段? 最好的祝福, 睚 以上来自于谷歌翻译 以下为原文 Hi there, We need to design a led driver using the HVLED001A to supply a string of leds with 100w and 150w. According to datasheet we need to have two stages to supply this power but in eDesignSuite we have not found a way to do it. Is there a way to use the eDesignSuite to calculate my driver for 100W and 150w with two stages? Best regards, Jair |
3个回答
你好,
eDesignSuite不允许自动创建两个阶段的设计。 您可以分两步使用eDesign:使用HVLED001A设计电源,然后使用我们工具中可用的另一个DC / DC设计降压级。 如果您需要其他详细信息,请告诉我。 问候, 帕特里齐亚 以上来自于谷歌翻译 以下为原文 Hello, eDesignSuite doesn't allow to create automatically a design with two stages. You can use eDesign in two steps: design a power supply with HVLED001A and then design the step-down stage using another DC/DC between those available in our tool. Let me know if you need other details. Regards, Patrizia |
嗨Patrizia,
感谢您的回复。 有没有参考设计或应用说明如何使用HVLED001A 两个阶段? 当你说两个阶段我明白变压器有两个 secundary阶段提供两个50W或75W的LED串。我们准备去 使用一个HVLED001A和一个MOSFET来控制LED校正。是对的吗? 如何在此配置中设计此变压器? 最好的祝福, Jair Ruiz Sakae Microtarget Tecnologia Digital Ltda。 电话:55-11-2574-7263传真:55-11-5181-2387 http://www.microtargetrep.com.br< http://www.microtargetrep.com.br/> 以上来自于谷歌翻译 以下为原文 Hi Patrizia, Thank you for reply. Is there any reference design or application note how to use HVLED001A with two stages? When you are saying two stages I understand that the transformer has two secundary stages to supply two led strings of 50W or 75W. We are going to use one HVLED001A and one MOSFET to control the led corrent. Is that right? How to design this transformer in this configuration? Best regards, Jair Ruiz Sakae Microtarget Tecnologia Digital Ltda. Tel.: 55-11-2574-7263 Fax: 55-11-5181-2387 http://www.microtargetrep.com.br |
嗨Jair,
对于PFC部分,请使用L6562A控制器,有关设计步骤,请参见AN2761。关于基于HVLED001A的反激部分,请使用eDesignSuite。 最好的祝福, ROGA©里约热内卢 以上来自于谷歌翻译 以下为原文 Hi Jair, For PFC section, pls use L6562A controller, see AN2761 for design procedure. In regards to flyback section based on HVLED001A pls use eDesignSuite. Best regards, Rogério |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 19:04 , Processed in 0.653188 second(s), Total 49, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
443
