当使用模拟器时,我的新mplab x 3.40拒绝更改配置位选项以使PORTB位0到4数字输出。尽管配置位窗口显示我更改了PBADEN选项,使引脚数字输出,但它们仍然作为模拟输出出现在IDE的I/O引脚窗口中。相同的代码在3.10版中完美地工作。这是虫子吗?我正在模拟PIC18F420。我附上了相关窗口的代码和输出。
以上来自于百度翻译 以下为原文 My new mplab x 3.40 refuses to change the configuration bits option to make PORTB bits 0 to 4 digital output when using the simulator. They still appear as analogue outputs in the I/O pins window of the IDE even though the configuration bits window shows I changed the PBADEN option to make the pins digital outputs. The same code works in version 3.10 perfectly . Is this a bug? I am simulating the PIC18F4520. I have attached the code and the outputs of the relevant windows. Attached Image(s) Attachment(s) PORTB_TURN_ON.asm (1.04 KB) - downloaded 77 times |
3个回答
我们需要更多的信息来识别这个问题。你的项目使用哪种设备?如果你能给我们一个项目或一段代码来再现这个问题,这将帮助我们找到问题的根本原因。
以上来自于百度翻译 以下为原文 We will need more information to identify the issue. Which device do you use for your project? If you could give us a project or a piece of code which will reproduce the issue, that will help us find the root cause of the problem. |
黄金法则是“从端口读取并写入LAT”。我看不到你的配置设置。你能在硬件上试试这个吗?它很可能是一个bug(虽然这在它降低机会之前起作用)。苏珊
以上来自于百度翻译 以下为原文 The golden rule is to "read from the PORT and write to the LAT". I can't see your config settings. Can you try this on hardware - it may well be a bug (although if this worked before it lowers the chances). Susan |
是的,这是个问题,我们将在接下来的几个月内得到解决。但我相信同时也有一个工作。转到Projtudio属性-GT;模拟器-GT;重置,并切换模拟器执行POR重置而不是MCLR重置。然后执行复位,您应该看到引脚配置正确。
以上来自于百度翻译 以下为原文 Yep this is an issue which we will get fixed in the next few months. But I believe there is a work-around in the mean time. Go to Project Properties -> Simulator -> Reset, and switch the simulator to perform POR resets instead of MCLR resets. Then perform a reset, and you should see the pins configured correctly. |
只有小组成员才能发言,加入小组>>
4976 浏览 9 评论
1898 浏览 8 评论
1831 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3044 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2123 浏览 5 评论
554浏览 1评论
404浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
456浏览 0评论
347浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
829浏览 0评论
GMT+8, 2024-8-6 01:28 , Processed in 1.157593 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
