很长一段时间,V3.40已经很好地保存并恢复了IDE窗口窗格的配置。当我启动MPLAB X时,它和上次关闭时的窗口完全一样。现在,由于某种原因,这已经停止了。我喜欢V3.40用户手册第82页所示的基本安排。屏幕的右边部分在编辑器窗格(顶部)和任务窗格(在底部)之间划分,没有一个“标题栏”来浪费空间。但是现在,每当我启动时,任务窗格只是它与编辑器共享的窗格中的另一个选项卡。例如,“输出”只是顶部的另一个标签,上面有我正在编辑的源文件的名字。我可以随意翻转窗格并最终恢复正常,但它们不会在重新启动时保存。我必须每天都这么做。单一的。时间。选择只查看编辑器或任务窗格是不可行的;它使单步执行几乎无用,因为您不能查看变量等。因此,我被迫重新排列窗格,只需要下次再做。下次再来。下次再来。你知道了,直到一天以前,这一切都不是真的。一切都被保存和恢复了。我不知道为什么这种行为改变了,但我想回去!我已经搜索了用户手册,但找不到任何具体的关于告诉MPLAX X来保存窗格排列。有人有什么建议吗?我会非常感激的。诚然,这是一个小问题,但令人惊讶的是如何分散这样一个小事情可以。谢谢!
以上来自于百度翻译 以下为原文 For a long time, v3.40 has nicely preserved and restored its IDE window pane arrangements. When I launch MPLAB X, it arranges the windows exactly the same as when it last shut down. Now, for some reason, that has stopped. I like the basic arrangement shown on page 82 of the v3.40 user manual... the right part of the screen is divided between the editor pane (on top) and the task pane (on bottom), with no "title bar" on either one to waste space. But now, every time I start, the task pane is just another tab in a pane it shares with the editor. "Output", for example, is just another tab along the top with the names of the source files I'm editing. I can fiddle around with the panes and eventually restore things to normal, but they're not preserved across re-launches. I have to do it Every. Single. Time. It is not really workable to choose to view ONLY the editor OR the task pane; it makes single stepping almost useless because you can't watch variables, etc. So I'm forced to rearrange the panes, only to have to do it again next time. And again next time. And again next time. You get the idea. None of this was true until a day or so ago. Everything was preserved and restored. I don't know why this behavior changed, but I want to go back! I've searched the user's manual but can't find anything specific about telling MPLAB X to preserve pane arrangement. Anyone have any suggestions? I'd be most appreciative. Admittedly a minor issue, but it's amazing how distracting a little thing like this can be. Thanks! |
5个回答
当MPLabX变得混乱时,清除缓存有时可以解决问题。缓存文件夹在“帮助”框中列出。当MPLabX没有运行时,必须删除。
以上来自于百度翻译 以下为原文 When MPLabX becomes confused clearing the cache can sometimes solve the problem. The cache folders are listed in the help about box. The must be deleted when MPLabX is not running. |
好了,试试看,得到了部分改进(谢谢!)现在它似乎记得窗口排列(至少对于一个项目),但是当一个项目被关闭时,输出窗口变为全屏,而不是像过去那样走开。这是可以容忍的,但奇怪的是,任何事情都改变了,我不能让它回去。谢谢你有用的提示,它确实改进了事情!
以上来自于百度翻译 以下为原文 OK, tried that and got a partial improvement (thank you!). Now it appears to remember the window arrangement (at least for one project), but when a project is closed the Output window zooms to full screen instead of going away like it used to. This is tolerable, but it's weird that anything changed at all - and that I can't get it to go back. Thank you for the useful tip, it definitely improved things! |
是的,但是我已经经历了痛苦的经历,而不是在一个项目中改变/升级工具!这不是一个“bug”本身,它工作得更早,所以我知道这个版本可以做到这一点。只是感觉像一个配置错误或什么,但我找不到一个选项,可以控制它。删除缓存似乎有帮助,所以我们可以通过目前的项目。
以上来自于百度翻译 以下为原文 Yes, but I've learned through painful experience not to change/upgrade tools in the middle of a project! And this isn't a "bug" per se, it was working fine earlier so I know this version could do it. Just felt like a configuration error or something but I can't find an option that would control it. Erasing the cache seems to have helped, so we can get through the present project. |
是的,但是我已经经历了痛苦的经历,而不是在一个项目中改变/升级工具!嗯,是的,我同意MPLAX X有(少数之一)优势,你可以保留旧版本…
以上来自于百度翻译 以下为原文 Yes, but I've learned through painful experience not to change/upgrade tools in the middle of a project! Well yes I agree MPLAB X has the (one of the few) advantage, that you can keep old versions... |
只有小组成员才能发言,加入小组>>
5053 浏览 9 评论
1938 浏览 8 评论
1877 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3094 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2161 浏览 5 评论
602浏览 1评论
470浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
321浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
497浏览 0评论
404浏览 0评论
GMT+8, 2024-9-11 14:41 , Processed in 1.311994 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
