电子发烧友论坛|
你好。。。
我是新的CyPress控制器,我刚刚开始在CY7C64 35648 LTXC控制器上工作。我正在做ADC LCD编码。在这里,我的问题是,我得到ADC输出,这是我再次转换为电压和DelPauliIn Bon LCD。如果我用万用表测量的输出电压与ADC的输出电压不匹配。我使用的是外部分压电路(电位器)。有人能帮我整理一下吗? 这是我的密码。 事业单位 包含和M8C.H>/部分特定常数和宏 包含所有用户模块的“pSOAPAPI .h”//PSoC API定义 包括“STDLIB H” 空隙主(空隙) { int瓦尔=0,FLAG=0; 浮标比例系数;电压; /INT结果; 字符结果; INT状态; LCDX START();/初始化LCD 标志=(PRT0DR和0x01); MUXYCR1=标志;/ /连接ADC到P0.0的输出 AdcCnCART启动(ADCSCIN) LCDI位置(0,0); LCDA PRCSTROM(“ADCX输出=”); LCD-PRECHECItiN(FLAG); LCDI位置(1,0); LCDA PRCSTROM(“ADCYVIN=”); (1) { //Val= ADCcNIN GETSAMPLE();/ /获取ADC值 //同时(AcccNdFasDATAsAccess()) { Val= ADCcNIN GETSAMPLE(); LCDI位置(0,12); LCD-PrHuxIn(VALL); 电压=(VAL/(浮点)1023); 电压*=(3.3); //电压=(Val*尺度因子); 结果= FTOA(电压,和状态); LCDI位置(1,8); LCDPPRSTRON(结果); //LCDPrPrScLy(“V”); } } } 以上来自于百度翻译 以下为原文 Hello... I am new to this cyppress controllers,I have just started to working on CY7C6435648LTXC controller.I was doing ADC LCD coding. Here my problem is I am getting the ADC output,that again i am converting to voltage and displayiingbon LCD.That output voltage if i am measureing with the multimeter that is not matching with the output voltage of ADC. I am using external voltage divider circuit (potentiometer). Can any one help me to sort out this. And this is my code. -======================================================================================= #include #include "PSoCAPI.h" // PSoC API definitions for all User Modules #include "stdlib.h" void main(void) { int val = 0, flag = 0; float Scaling_factor,voltage; //int Result; char *Result; int status; LCD_Start(); //Initializing LCD flag = (PRT0DR & 0x01); MUX_CR1 = flag; //Connecting Output of ADC to P0.0 ADCINC_Start(ADCINC_INPUT_ANALOG_BUS);//Start conversion LCD_Position(0,0); LCD_PrCString("ADC_OUTPUT = "); LCD_PrHexInt(flag); LCD_Position(1,0); LCD_PrCString("ADC_Vin="); while(1) { //val = ADCINC_GetSample(); //get the ADC value //while(ADCINC_fIsDataAvailable()) { val = ADCINC_GetSample(); LCD_Position(0,12); LCD_PrHexInt(val); voltage= (val /(float)1023); voltage *= (3.3); //voltage = (val * Scaling_factor); Result = ftoa(voltage , &status); LCD_Position(1,8); LCD_PrString(Result); //LCD_PrCString("v"); } } } |
4个回答
顺便说一下,在设计器的起始页面上有一个例子
你可以从本质上看你所做的项目。 试图去做。 以上来自于百度翻译 以下为原文 By the way, on start page of Designer there is an example project you can look at that does essentially what you are trying to do. |
我想给你看的照片,附上。
模数转换器液晶投影 288.3 K 以上来自于百度翻译 以下为原文 The pic I tried to show you, attached.
你起床了吗?问题解决了吗?
问候,Dana。 以上来自于百度翻译 以下为原文 Are you up and running, problem solved ? Regards, Dana. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 10:08 , Processed in 0.843140 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2438
