电子发烧友论坛|
嗨,我有两个RN 4870的问题,因为我尝试模块到模块连接。我工厂重置它们,然后按照用户指南的步骤(连接示例-gt;模块到模块连接)。但是,即使所有的响应都与指南中的相同,当连接时,连接也不能保持超过一秒钟。输入命令c,0,
以上来自于百度翻译 以下为原文 Hi, I have a problem with two RN 4870's as I try the module to module connection. I factory reset them, then follow the steps on the User Guide (connection examples -> module to module connection). However, even though all the responses are the same as on the guide, when it comes to connecting, the connection can't be held for more than a second. After inputting the command: c,0, Sometimes, however, the modules are able to open the stream of data before disconnecting, but it happens randomly. Also, when I try to connect to it with an Android device + SmartDiscover, the same thing happens. Is that most likely to be a firmware problem? Thanks |
3个回答
嗨,先生,你正确地设置了特征(SR)吗?当我把一个不可能的特性放在我的模块中时,我遇到了同样的问题。试着用(d)命令来检查它。你能检查一下你的电路是否短路了?当您错误连接并发送错误MSG模块重置/断开。您在新连接之前重置模块吗?通常也和我在一起。你检查了模块的版本吗?有时你会设置你的模块没有的东西。祝你好运。
以上来自于百度翻译 以下为原文 Hi sir, Did you set the feature (SR,) correctly ? I had been the same problem when I put a impossible feature in my modules. Try to use a (D) command to check it. Can you check if you have a short circuit in some part? When you connect wrongly and send a error msg the module reset/disconnect. Did you reset the module before the new connection? Usually it's wook with me too. Did you check the version of your modules ? Sometimes you set something that your module didn't have. Good luck |
你好,我也有同样的问题。我正在使用RN4780PICTAIL板,它直接连接到一台带有USB的主机。它正在运行1.18.2版的固件,所以我更新到1.18.3。我按照快速启动指南中所说的那样做了:按顺序发送:S-,BLESS,C0R,1然后用c检查设置ommand“d”,看起来还可以。然后当我尝试用SmartDiscover与我的智能手机连接时,它开始运行良好,但是立即断开……输出:“%CONNECT,159507872FD30%%DISCONNECT%”“pictail已打开,没有任何修改。有人能解决这个问题吗?
以上来自于百度翻译 以下为原文 Hello, I have the exact same problem. I'm using the RN4780 PICTAIL board directly connected to a host PC with USB. It was running firmware version 1.18.2 out of the box so I updated to 1.18.3. I did exactly what is said in the quick start guide: Sent in order: S-,BLE SS,C0 R,1 Then checked the setting with command "d", and seemed ok. Then when I try to connect with my smartphone with SmartDiscover, it goes well at first but it disconnect immedialty... output : "%CONNECT,1,59507872FD30%%DISCONNECT%" The pictail is out of the box, no modification at all. Does Anyone have a solution to this ? |
一大堆!非常感谢,现在工作很好,甚至有私人关贸总协定的服务。
以上来自于百度翻译 以下为原文 Hepful ! Thanks a lot. Works fine now, even with private GATT services. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:42 , Processed in 0.643819 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1436
