电子发烧友论坛|
大家好,
我刚才买了一块斯巴达3an板。 不小心,我插了一个错误的电源适配器,而不是斯巴达套件的适配器。 现在,即使连接正确的适配器,电源LED也会闪烁。 我注意到调节器电路坏了。 我是否有可能再制作一个额外的调节板来为斯巴达提供动力? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi all, I have purchased a spartan 3an board a while ago. Accidentally, I have plug a wrong power adapter which is 12V instead of spartan's kit's adapter. Now, the power LED is blinking even when I connect the right adapter. I've notice that the regulator circuit has broke. Is it any possibilities that I make an additional regulator board to power the spartan again? Thanks. |
1个回答
该套件的原理图仍应在线。
你可以开始更换零件 认为你可能会修理电路板,但过电压很可能超过了监管机构 并且还炒其他薯条。 如果是我,我会尝试更换监管机构,如果是的话 没有解决它,废弃董事会。 如果您不方便更换QFN封装,您可以使用外部电源 产生所有所需的电压并将其连接到调节器周围的跳线上 (每个电源都有一个直插式跳线)。 带注释的示意图在表5中显示了这些: 1.2V FPGA内核(开关) 3.3V FPGA I / O(开关) 3.3V FPGA Aux(线性) 1.8V USB / JTAG(线性) 0.9V DDR2 Vtt(切换) 1.8V DDR2(开关) 3.3V DAC参考(线性) 0.9V DDR2 Vref(线性) 您可能会尝试仅为前三种耗材供电,看看您是否从中获得了生命 在进行任何进一步的手术之前。 [编辑] 哎呀,我刚注意到你说Spartan 3AN而不是Spartan 3A。 abover评论是 基于Spartan 3A套件。 你的无疑会有所不同,但无论如何你应该挖掘 电路板原理图,看看它是否具有相同的电源功能。 - Gabor 以上来自于谷歌翻译 以下为原文 The schematics for that kit should still be on line. You could start replacing parts if you think you might fix the board, but it is quite likely that the overvoltage got past the regulators and fried other chips as well. If it were me, I'd try to just replace the regulators, and if that didn't fix it, scrap the board. If you're not comfortable replacing the QFN packages, you could have an external supply that generates all of the required voltages and attach it to the jumpers that surround the regulators (every supply has an in-line jumper). The annotated schematic shows these on sheet 5: 1.2V FPGA core(switching) 3.3V FPGA I/O (switching) 3.3V FPGA Aux (linear) 1.8V USB/JTAG (linear) 0.9V DDR2 Vtt (switching) 1.8V DDR2 (switching) 3.3V DAC reference (linear) 0.9V DDR2 Vref (linear) You might try powering just the top three supplies to see if you get any life out of the board before doing any further surgery. [Edit] Oops, I just noticed you said Spartan 3AN and not Spartan 3A. The abover remarks were based on the Spartan 3A kit. Yours will no doubt be different, but in any case you should dig up the board schematics and see if it has the same power features. -- Gabor |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:59 , Processed in 0.562716 second(s), Total 69, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1312
