电子发烧友论坛扫一扫,分享给好友
大家好,我想知道如何参数化两个对象的相对距离。
我想物理地将一个物体相对于由气隙隔开距离Z0的另一物体移位。 然后我想按照我的要求沿X,Y或Z方向移动物体。 我该怎么做呢? 可以将诸如协同仿真的EMPro结果导回到ADS 2011布局工具中吗? 我在PCB上看到了一个关于youtube的演示,并在PCB上安装了一个3D对象。 该演示包括原理图,布局和布局包括3D对象虽然在2D中是平的,但是当击中3D视图时它将显示组件。 我想用两根天线做类似的事情。 我想将电压源应用于一个天线(参考),由气隙隔开的第二个天线将拾取H场,并产生电压/电流输出(EMPro域)。 我想获取该电流/电压(EMPro - >布局域)并将其整流为直流电压(原理图域)。 我想绘制从一个天线传输到另一个天线的能量的时域。 第一步是知道如何使用EMPro中的参数F(x)将它们链接到一个对象并以参数方式移动它们,稍后我必须找出如何告诉工具两个天线将通过电感和磁场进行一些耦合 ...我希望这个工具足够聪明,可以知道E / H场存在,所以另一个天线会拾起它。 任何这些错综复杂的项目的任何帮助将不胜感激。 我的电子邮件是rjrodrig@yahoo.com 以上来自于谷歌翻译 以下为原文 Hello everyone, I would like to know how to parametrize the relative distance of two objects. I would like to physically displace one object relative to another object separated by an air gap by a distance Z0. Then I would like to move the object either along the X,Y , or Z directions as I please. How do I do this? Can an EMPro results such as Co-simulation be imported back into ADS 2011 Layout tool? I saw a demo on youtube on a PCB and a 3D object mounted on the PCB. The demo included Schematic, Layout, and the Layout included the 3D object though it was flat in 2D, but when hitting the 3D view it would display the component. I want to do something similar, with two antennas. I want to apply a voltage source to one antenna (Reference), and a second antenna separated by an air gap will pick up the H-Field, and produce a voltage/current out (EMPro Domain). I want to take that current/voltage(EMPro ->Layout domain) and rectify it in to a DC voltage (schematic domain). I want to plot a time domain of the energy transferred from one antenna to another. First step is to know how to use the parameters F(x) in EMPro to link them to an object and displace them parametrically, later I have to find out how to tell the tool the two antennas will have some coupling via inductance and magnetic field... I would hope the tool is smart enough to know E/H field is present and so the other antenna will pick it up. Any help one any of this convoluted items would be greatly appreciated. My email is rjrodrig@yahoo.com |
7个回答
Bueller?
......布勒? ......布勒? ....任何人?编辑:rjrodrig于2013年3月28日下午2:56 以上来自于谷歌翻译 以下为原文 Bueller? ... Bueller? ... Bueller? .... Anyone? Edited by: rjrodrig on Mar 28, 2013 2:56 PM |
有各种方法来参数化距离。 一种方法是通过“约束”。 但是您必须同时绘制两个对象以应用约束。 在2D草图窗口中,存在“距离”约束,可用于设置两个线段之间的距离。 如果要对现有对象执行此操作,则可以使用“指定方向”并将原点锚定到现有对象的任何顶点或面/边,然后使用“Tab”绘制2D草图以输入坐标。 从EMPro 2012开始,您可以直接从ADS访问EMPro设计。 这将允许您根据IP3或增益压缩等电路规格扫描/调整/优化3D设计。 这里附有一个例子。 在此示例中,在ADS中优化了条带到通孔转换设计(在EMPro中完全参数化)。 以上来自于谷歌翻译 以下为原文 There are various ways of parameterizing the distance. One way of doing it is through "Constraints". But you have to draw the two objects at a same time to apply the constraints. In the 2D sketch window, there is "distance" constraints that can be used to set a distance between two line segments. If you want to do this on existing objects, then you can use "specify orientation" and anchor the origin to any vertex or face/edge of an existing object, then draw your 2D sketch using "Tab" to enter the coordinate. Starting from EMPro 2012, you can access EMPro design from ADS directly. This will allow you to sweep/tune/optimize your 3D design against circuit specifications such as IP3 or gain compression. One example is attached here. In this example, a strip to via transition design (completely parameterized in EMPro) is optimized in ADS. 附件
谢谢你的解释。 我必须使用我在Solidworks中创建的对象并将其导入到Empro 2011中。我想我可以添加约束来从ADS原理图中来回移动它,使用Empro 2011创建4个距离点的扫描。我在你看到了一个视频管 显示他们可以从ADS uW模拟EMPro组件,并且它不是EMpro 2012(http://www.youtube.com/watch?v=_9TmUUtV95o)我仍在努力为我的PICC天线添加端口。 我收到警告说:!!!警告!!!!!!!!!!!!! 端口1的阻抗线的起点未连接到导电物体! !!!!!!!!!!!!!!!!!!!!!!!!!! !!!警告!!!!!!!!!!!!! 端口1的阻抗线的终点未连接到导电物体! !!!!!!!!!!!!!!!!!!!!!!!!!! 我读了线程https://community.keysight.com/message/27912#comment-27912并按照你的建议,但它不起作用! 我无法模拟PICC天线。 你帮助我的第一个天线工作,并在我的电脑上运行。 然后我按照你对它做的,我将它复制到我的PICC天线上,我无法模拟它。 它出错了。 几何是正确的,端点是接触金属,但它拒绝模拟天线。 附件是我想要做的。 任何帮助都将得到无限的赞赏......从本质上讲,如果只有2012年能够做到这一点,我认为我是使用EMPro的东道主。 问候,罗伯特 Move_Antennas.zep219.0 KB 以上来自于谷歌翻译 以下为原文 Thank you for the explanation. I have to objects which I created in Solidworks and imported the into Empro 2011. I thought I can add the constraints to move it back and forth from ADS schematic creating a sweep of 4 distance points using Empro 2011. I saw a video in you tube showing they can simulate EMPro components from ADS uW, and it was not EMpro 2012 (http://www.youtube.com/watch?v=_9TmUUtV95o) I am still struggling with adding a port to my PICC antenna. I get warnings saying : !!!Warning!!!!!!!!!!!!! The start point of the impedance line of port 1 is not connected to a conducting object! !!!!!!!!!!!!!!!!!!!!!!!!!! !!!Warning!!!!!!!!!!!!! The end point of the impedance line of port 1 is not connected to a conducting object! !!!!!!!!!!!!!!!!!!!!!!!!!! I read thread https://community.keysight.com/message/27912#comment-27912 and followed your suggestions there but it does not work! I can't simulate the PICC antenna. The first antenna you helped me with it worked, and ran in my PC. I then followed what you did on it, and I replicated it on my PICC antenna, I can't get it to simulate. It errors out. The geometry is correct, the end points are touching metal, yet, it refuses to simulate the antenna. Attached is that I am trying to do. Any help will be infinitely appreciated... In essence it sounds I am host using EMPro if only 2012 can do it. Regards, Robert 附件
小蜜蜂12346 发表于 2019-7-1 15:43 你好,我发现端口崩溃的问题是由于我有两个空气部件称为空气上面的空气,而空气低于...我删除了那些,我没有得到端口错误。 我现在面临网格应用程序崩溃。 它开始优化网格,并在它开始写一些文件后立即崩溃。 也许网格设置设置不正确......无论我如何通过调整参数进行设置,它都会崩溃,我会得到小型转储,模拟最终会出现错误。 我不知道如何阻止它这样做。 我已经阅读了帮助文件,我不知道在网格菜单中如何选择和选择什么来调整网格,它们不像ADS Momentum Microwave那样在视觉上显示。 也许这就是问题,也许它会产生无限的网格,而且我的内存耗尽。 我真的不知道问题是什么,如果你看一下我会很感激。 请让我知道我做错了什么以及为什么它没有模拟。 问候,罗伯特 以上来自于谷歌翻译 以下为原文 Hello, I figured out that the issue with the port crashing was due to the fact I had two Air PARTS called Air above, and Air below... I deleted those and I don't get the port errors. I am now facing mesh application crashes. It starts optimizing the mesh, and right after it starts writing some files, it crashed. Maybe the mesh settings are incorrectly setup... No matter how I set it up by adjusting the parameters, it crashes, and I get mini-dumps, and the simulation ends up in Error. I don't know how to prevent it from doing that. I have read the help file, and I don't know how and what to select in the mesh menu to adjust the mesh grid, they don't get displayed visually as in ADS Momentum Microwave. Maybe this is the issue, maybe it is generating infinite mesh, and I run out of memory. I really don't know what the issue is and I would appreciate if you take a look at it. Please let me know what I did wrong and why it doesn't simulate. Regards, Robert 附件
小蜜蜂12346 发表于 2019-7-1 16:02 这是因为您在FEM填充编辑器中设置了“使用PEC作为背景材质”。 这意味着除了对象之外,到处都是PEC。 这使端口连接到导致错误的接地。 当您绘制传输介质(例如波导中的空气而不是真实物体)并将外边界绘制为PEC时,您仅使用“PEC作为背景材料”。 以上来自于谷歌翻译 以下为原文 It's because you set "Use PEC for background material" in FEM Padding Editor. This means everywhere will be PEC other than objects. This makes ports are connected to grounds which cause an error. You only use "PEC for background material" when you draw the transmission media such as air in waveguide not the real object and making outer boundary as PEC. |
真? 我用过Air和铜。 如果你看到PEC,那一定是错误的。 我无法成功运行此SIM卡。 我用solidworks重新创建了图稿,确保线圈路径没有中断,但EMpro拒绝模拟它。 它在网格管理器中死亡,创建了核心转储。 我仍然无法按照您上次建议的方式在EMpro中找到故障排除工具。 如果不是太麻烦,你可以张贴一张图片,显示我可以说启用连续性问题的地方,或者知道为什么我的模拟会死掉? 我注意到当我在Empro中本地绘制跟踪(无导入)时,它会模拟它,但是当它被导入时,它很难做到。 我不知道为什么,但这是我的直觉。 有什么想法吗? 以上来自于谷歌翻译 以下为原文 Really? I used Air, and copper. If you saw PEC, then that must've been an error. I can't successfully run this sim. I have recreated the artwork with solidworks ensure there are no breaks in the coil path, but EMpro refuses to simulate it. It dies at the mesher creates core dump. I still cannot find troubleshooting tools within EMpro as you suggested last time. If it is not too much trouble, can you post a picture showing where I can enable say continuity issues or know why my simulation dies? I noticed that when i draw a trace natively (no import) in Empro, it simulates it, but when it is imported it has a hard time doing it. I am not sure why, but this is my gut feeling. Any thoughts? |
请参阅以2011格式保存的附件项目。 以上来自于谷歌翻译 以下为原文 Please see the attached project which was saved in 2011 format. 附件 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:51 , Processed in 1.013007 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2891
