电子发烧友论坛|
我已经将几个任意波形加载到我的Model 33522A中,它们存储在332XX_ARBS文件夹中。
如何仅使用前面板控件删除一个或多个这些波形? 非常感谢。 以上来自于谷歌翻译 以下为原文 I've loaded several arbitrary waveforms into my Model 33522A, where they're stored in the folder 332XX_ARBS. How can I delete one or more of these waveforms using only the front-panel controls? Many thanks. |
2个回答
您好,要删除arb文件,您需要按SYSTEM按钮,然后按系统设置软键,然后按管理文件软键。
这将带您进入文件管理器,默认操作为COPY,您需要按最左侧的软键并将其更改为删除。 然后按浏览软键并选择要删除的文件。 选择文件后,请确保在按完之前按“执行删除”软键。 以上来自于谷歌翻译 以下为原文 Hello, To delete arb files you need to press the SYSTEM button, then press the system setup softkey, then the manage files softkey. This will take you into the file manager, the default action is COPY, you need to press the far left softkey and change this to delete. Then press the browse softkey and select the file you wish to delete. After you select the file make sure you press Perform Delete soft key before pressing done. |
我很高兴它对你有用。
我同意用户界面的某些方面很笨拙/不明显。 文件系统绝对是其中之一。 我们一直在寻求提高可用性,因此欢迎所有反馈和问题。 感谢您的反馈。 以上来自于谷歌翻译 以下为原文 I'm glad it worked for you. I agree there are some aspects of the user interface that are clumsy/not obvious. The file system is definitely one of them. We are always looking to improve usability so all feedback and questions are always welcome. Thanks for the feedback. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:28 , Processed in 0.790071 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1784
