我开始开发一个智能手机界面系统。
这个想法是开发一些服务一起工作,例如HID和ANCS/ANS。 所有这些功能都可以在智能手机上不使用应用程序。 在你看来,在你的微宇宙中有这种服务是可能的吗? 当然,这意味着Ad Hoc的实现,因为所有的供应商都在使用Apple。 我对这件事很感兴趣,如果有人能给我一个答复,我将非常感激。 以上来自于百度翻译 以下为原文 I'm starting to develop a system for smartphone interface. The idea is to develop some services that work together for example HID and ANCS/ANS. All this functions are possible to work without APPs on the smartphone. In your opinion it is possible to have this kind of services in your micro? Of course this means an implementation ad hoc because all the suppliers work with APPS. I'm very interesting in this matter, if someone could give me a response, I'll appreciate very much. |
3个回答
听起来你想知道是否有可能编写可以相互交流的软件库?答案是肯定的。
或者,您可能会问,是否有可能在库中动态启用/禁用服务/功能?我相信这是可能的,但我不确定有什么好办法去做。从理论上讲,在手机上运行的任何东西都可以在微控制器上运行,因为手机只是一个有很多外设和大电池的大微控制器。(还有数千小时的软件代码)。 我想说你的问题的答案是肯定的: 以上来自于百度翻译 以下为原文 It sounds like you want to know if it is possible to write software libraries that can interact with each other? The answer is yes. Or maybe, you are asking if it is possible to dynamically enable/disable the services/functions in the libraries? I believe it is possible, but I'm not sure of a good way to go about doing it. Theoretically, anything that runs on a phone can run on a microcontroller, since a phone is just a big microcontroller with lots of peripherals and a large battery. (And thousands of hours of software code). I would say the answer to your question overall is a yes :) |
谢谢你的回复。
第二个请求是,如果有一些例子,使用CyPress BLE Micro,然后有更多的服务,我可以用来测试。换句话说,我确信你有一些实现单一服务的例子,但我没有看到不同的例子。 再次感谢 以上来自于百度翻译 以下为原文 Thank you for the response. The second request is if there are some examples, using the Cypress BLE micro, with more then one services that I can use for testing. In other words I'm sure that you have some examples with single service implemented, but I don't see different examples. Thanks again |
该页面有一些示例,但不确定其中的任何一个在同一个实例上实现了多个服务:HTTP://www. CyPress .COM/DooptTys/Studio/Studio/CyPress定制-BLU-PrruleS-服务
我想这个例子的BLE方面很容易集成,因为GATT DB在服务上异步地或多或少地处理事情。至于主要的.C代码,你必须编写它来实现你的想法: 这个项目看起来像一个“CasSoC”和“RGB LED”一起服务,可能是一个很好的起点?HTTPSE//GITHUBCOM/CyPress半导体ToC/COPS-4-BLUE/TRAE/MARST/100A项目 以上来自于百度翻译 以下为原文 This page has some examples, but not sure any of them have multiple services implemented on the same example: http://www.cypress.com/documentation/software-and-drivers/cypresss-custom-ble-profiles-and-services I would think the BLE side of the example is easy to integrate, as the GATT DB handles things more or less asynchronously across services. As far as the main.c code, you would have to write it to implement what you are thinking :) This project looks like it has both a "CapSense" and a "RGB LED" service together; Possibly a good starting point? https://github.com/cypresssemiconductorco/PSoC-4-BLE/tree/master/100_Projects_in_100_Days/Day003_Custom_Profile_CapSense_RGB_LED |
只有小组成员才能发言,加入小组>>
742个成员聚集在这个小组
加入小组2011 浏览 1 评论
1773 浏览 1 评论
3561 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1705 浏览 6 评论
1473 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
296浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
200浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
363浏览 2评论
303浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
502浏览 2评论
GMT+8, 2024-9-28 18:12 , Processed in 0.813183 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
