电子发烧友论坛|
我设置了一个具有3个协调器的miwi pro堆栈,这三个协调器都使用相同的pan id和共享公共信道连接。一个泛协调器和3个协调器像网状网络一样连接,在任何给定时间,我也可以通过任何协调器和泛协调器访问协调器数据。所以,问题是,如果任何协调器由于某种原因而断开连接,那么该协调器的最后一次接收数据仍然通过其他协调器显示。我想要的是,如果任何节点丢失了连接,我就应该能够检测哪个节点丢失了。仲裁者已经失去了…?关于一些帮助。这里是我在代码中所做的,但是它对我没有帮助。“如果(连接表。状态。
以上来自于百度翻译 以下为原文 I setup a miwi pro stack with 3 coordinators, all the three coordinators are connected with the same pan id and shared common channel. 1 pan coordinator and 3 coordinators are connected like a mesh network, at any given time i can access coordinators data through any of the coordinators and pan coordinator as well. So the Problem is, if any of the coordinators drops connection due to some reason, still last received data of that coordinator showing up through the other coordinators. what I wanted is, if any of the node lost the connection, i should be able to detect which node has lost.. SO how do find which coordinator has lost..? regards some help.. HERE is what i did in my code but its not helping me. "if(ConnectionTable.status.bits.isValid)" |
5个回答
嗨,你使用哪种MIWI版本?哪个PIC处理器?当做
以上来自于百度翻译 以下为原文 Hi, Which MiWi version do you use ? Which PIC processor ? Regards |
我很肯定“”在那里,但不可见,因为没有使用代码标签。您可以看到,在那一点之后字体转移到斜体。
以上来自于百度翻译 以下为原文 I'm pretty sure the "[ i ]" is there, but not visible because code tags weren't used. You can see the font shifts to italic after that point. |
“你使用哪种MIWI版本?”哪个PIC处理器?”HISRC,我使用MIWI演示工具包使用MRF89XA.PIC处理器ISPIC18F46J50。我有四个MIWI演示套件,在一个演示套件设置为一个PAN协调器和休息三他们作为一个协调员。你明白我的怀疑吗?
以上来自于百度翻译 以下为原文 "Which MiWi version do you use ? Which PIC processor ?" HI RISC, I am using MIWI DEMO kit using MRF89XA. PIC processor is PIC18F46J50. I have four MIWI DEMO Kit, in that one demo kit setup as a pan coordinator and rest three of them as a coordinators. DO you understand my doubt? |
我确信“”是存在的,但不可见,因为没有使用代码标签。你可以看到字体在那一点之后移到斜体。是的,我的意思是。
以上来自于百度翻译 以下为原文 I'm pretty sure the "[ i ]" is there, but not visible because code tags weren't used. You can see the font shifts to italic after that point. Yes, I meant that |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 10:26 , Processed in 1.039804 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
11262
