电子发烧友论坛扫一扫,分享给好友
我安装了PSoC创建者3.3和PSoC程序员。当我启动PSoC程序员时,我得到“PSoC程序员COM对象启动失败”的信息!……。我已经阅读了所有关于这个问题的现有任务,我安装/重新安装了创建者和程序员,我删除了驱动程序,我重新安装了驱动程序,我重新安装了创建者和程序员更新版本,我安装它作为“典型”,而不是作为“完整”,…等等。
结果是程序员给了我一个消息:“PSoC程序员COM对象启动失败!……“当我启动它,而创建者给了我错误消息Trn.M00 04”PSoC程序员没有安装在您的计算机系统上。……“当我开始的时候。 我在虚拟机上安装了一个不同系统的创建者。但我想让它运行在我的PC系统(Win XP,SP3)!!!!!!!! 请帮帮我,我已经结束了… 问候,托马斯 刺参 40.5 K 刺参 58.2 K 以上来自于百度翻译 以下为原文 I installed PSoC Creator3.3 and PSoC Programmer. When I start PSoC Programmer then I get the message "PSoC Programmer com-object failed to start! ....". I read already all the existing tasks regarding to this issue, I de-installed / re-installed the Creator and the Programmer, I deleted the drivers, I re-installed the drivers, I re-installed the Creator and the Programmer with updated versions, I installed it as "typical" and than as "complete", ....and so on. The result is that the Programmer gives me the message "PSoC Programmer com-object failed to start! ...." when I start it, and the Creator gives me the error-message trn.M0004 "PSoC Programmer is not installed on your coumputer system. ......", when I start it. I installed the creator on a different system in a virtual machine and there it worked. But I want to get it running on my PC-System (Win-XP, SP3) !!!!!! Please help me, ...I'm at my wits' end... Regards, Thomas
10个回答
即使使用SP 3,Psoc Creator 3.3也不会在XP上工作。升级到Windows 7或Windows 10。
以上来自于百度翻译 以下为原文 Psoc Creator 3.3 will not work on XP even if you are using SP 3. Upgrade to windows 7 or Windows 10. |
谢谢你的快速回答。顺便说一下,在一个虚拟的XP机器中它是有效的。由于VM计算机的恶劣环境(RAM),它的工作不稳定。
在第一步,我想熟悉的BLE话题,我只有胜利XP在这里。所以我不想通过额外的Wi7操作系统。 哪些版本是与WindowsXP一起工作的最新版本?我应该得到PSoC创建者、PSoC程序员和CyScript的版本号,因为XP在我的地方还没有Wi7。 最好的问候, 托马斯 以上来自于百度翻译 以下为原文 Thanks for your rapid answer. By the way, ...in a virtual XP machine it works. Because of the poor environment (RAM) of this VM computer unfortunately it works not stable. In a first step I want to get familiar with the BLE topic and I only have Win-XP here. So I don't want to by an extra Win7-OS for this. Which versions are the latest which are working with Windows XP? I should get the version numbers for the PSoC-Creator, the PSoC-Programmer and the CySmart which are working with XP because I do not yet have a Win7 here at my place. Best Regards, Thomas |
你好,
您可以在PSoC Creator发行说明中找到支持的操作系统: HTTP://www. CyPress .COM/FIL/290261下载安装-操作系统 你可以看到Windows XP SP3(32位支持)作为一个独立的,对于VM,它是不同的。 谢谢 乔宾GT 以上来自于百度翻译 以下为原文 Hello, You can find the supported OS in the PSoC Creator release notes: http://www.cypress.com/file/290261/download Installation - Operating System You can see Windows XP SP3 (32-bit supported) as a standalone, for VM it is different. Thanks JOBIN GT |
你好,
看来PSoC Creator 3.3正在运行,但PSoC程序员产生这些问题。但是在PSoC程序员(HTTP://wwwyCysP.com/FIL/46506/Access,第7页)的发行说明中,您可以看到它也应该与XP一起工作。那么为什么在使用XP时会收到这样的错误信息呢? 我看到一句话,PSoC Programmer应该“预装”给PSoC Creator。这是非常必要的还是只是推荐的,而不是要做的。 我订购了一台Win 7计算机,用于测试,另外用Wi7检查它,但我想让它运行XP。 当做, 托马斯 PSOC程序设计 187.3 K 以上来自于百度翻译 以下为原文 Hi, it seems that PSoC-Creator 3.3 is running but that the PSoC-Programmer generates these problems. But in the release notes of PSoC-Programmer ( http://www.cypress.com/file/46506/download , on page 7) you can see that it also should work with XP. So why do I get such error messages when using XP? I saw a remark that PSoC-Programmer should be "preinstalled" to PSoC-Creator. Is this strongly necessary or just recommended and not forded to be done. I ordered a Win7 Computer for tests to check it additionally with Win7 but I want to get it running with XP. Regards, Thomas |
我会尝试卸载PSoC程序员,然后重新安装CyPress。COM/程序员。
以上来自于百度翻译 以下为原文 I would try uninstalling PSoC Programmer, then re-installing from cypress.com/programmer. |
我已经重新安装了PSoC PRogrammer(在卸载后使用C清洗器进行注册表清理)。我已经重新安装了PSoC Creator(在卸载后使用C清洗器进行注册表清理)。…见我在这个论坛的第一个条目。
我已经下载了我尝试使用的所有软件的最新版本(程序员、创建者…和CyScript……大约2个星期前的版本)。 也许在CasCar没有删除的注册表中有一些重要的隐藏条目? 问候,托马斯 以上来自于百度翻译 以下为原文 I already re-installed PSoC-PRogrammer (with using CCleaner for registry cleaning after uninstalling). I already re-installed PSoC-Creator (with using CCleaner for registry cleaning after uninstalling). ....see my first entry in this forum. I downloaded already the nearest latest versions of all of the software which I (try to) use (Programmer, Creator ...and CySmart ....versions from about 2 weeks ago). Maybe there is some important hidden entry in the registry which the CCleaner did not delete? Regards, Thomas |
你能试试这个吗?
HTTP://wwwyCyp.com /FoMU/PSOC-Calor软件/ STEST-DESTORE安装-问题CyPress软件-创建者设计或 谢谢 乔宾 以上来自于百度翻译 以下为原文 Can you please try this: http://www.cypress.com/forum/psoc-creator-software/steps-resolve-installation-problem-cypress-software-creator-designer-or Thanks JOBIN |
谢谢Jobin,
为了确保所有的东西都被删除,我这样做了……我删除了(与Cype Manager一起安装)完整的CyPress工具(创建者,程序员,经理,等等)。然后我启动了“RealyRePixAptudio.exe”并删除了所有条目。之后我开始了CCulter。所以任何柏树程序都不应该留下任何东西。然后我重新启动了PC。在重新启动后,我只安装了PSoC程序员,然后我重新启动了PC。在重新启动之后,我试图启动PSoC Programmer。结果是,同一个PSoC程序员错误消息窗口像以前一样出现(见附件PSoC PrimeSyr.com .jpg)。 在此之后,我再次安装PSoC Creator,但结果没有改变(相同的错误消息窗口,…见附件,…PSOC-CalaRealErr.NO-PROG.JPG)。 问候,托马斯 PSOC-CytoRealErr.NO-PROP.JPG 58.2 K PSO-PrimeSkyr.C.JPG 40.5 K 以上来自于百度翻译 以下为原文 Thanks Jobin, to be sure that really everything is removed I did it this way, ...I removed (de-installed with Cypress-Manager) the complete cypress tools (Creator, Programmer, Manager, ...etc.). Then I started the "RegistryRepairApplication.exe" and removed ALL entries. After this I started CCleaner. So there should be nothing left from any cypress programs. Then I restarted the PC. After restart I installed only PSoC-Programmer, then I did a restart of the PC. After this restart I tried to start PSoC-Programmer. The result was that the same PSoC-Programmer-Error-Message window appears as before (see attachment PSoC-Prog_Err_COM.jpg). After this I installed PSoC-Creator again but the result did not change (same error message window, ...see attachment, ...PSoC-Creator_Err_no-Prog.jpg). Regards, Thomas
你好,
你能试试吗? 在管理员模式下打开命令提示符。(右键单击并选择“运行为管理员”)将目录更改为“c:程序文件(x86) CyPress 程序员”运行pSoCopeDeloC.Ex/ungServer运行的PSoCopyReloC.Ex/ReServer 谢谢 乔宾GT 以上来自于百度翻译 以下为原文 Hi, Can you try: Open Command Prompt in Administrator mode. (Right click and select ‘Run as administrator’) Change Directory to “C:Program Files (x86)CypressProgrammer” Run PSoCProgrammerCOM.exe /unregserver Run PSoCProgrammerCOM.exe /regserver Thanks JOBIN GT |
heks 发表于 2019-6-28 18:11 解决了我的问题。非常感谢! 以上来自于百度翻译 以下为原文 Solved my problem. Thank you very much! |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 05:21 , Processed in 0.888295 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4650
