自从一个多月以来,我总是得到“小窗口”没有菜单栏和舒适的大小。我已经跟踪到这是我的Internet Explorer IE10的一个设置,实际版本。我创建了一个MyCase.当没有回应的时候,我把它升级了。塞浦路斯的最后一个回应是一个月的承诺。在我的实验室里有几台机器能正确显示后窗,这两台机器的比较没有显示出明显的差别。取消和重新安装IE10并不能治愈这个错误。这是不可能的,我在这个机器上使用一个不同的浏览器比IE,因为一些安全限制,我已经签署并必须遵循。欢迎您的任何建议!鲍伯(绝望的)附图显示了我的“小窗口”错误。
JPG 66.7 K 以上来自于百度翻译 以下为原文 Since more than a month now I *always* get the "small window" without the menu-bar and comfortable size. I tracked down already this to be a setting of my internet-explorer ie10, actual version. I created a MyCase and when no response came I escalated it. Last response from Cypress now is one month old promising nothing. In my lab are a few machines that show the post-window correctly, the comparision of the two machines did not reveal a visible difference. De- and reinstallation of ie10 did not cure the error. It is not possible for me to use on this machine a different browser than ie due to some security restrictions I have signed and have to follow. Any suggestions from your side are welcome! Bob (desperated) Attached picture shows my "small Window" error.
6个回答
嗨,鲍伯,我以前从未见过这个错误。您的描述窗口似乎不能做拖动和展开。你有很多限制浏览器,我不能帮助它。在其他文章中,你说滥用链接已经死了,但是我的浏览器显示了那个按钮。可能这也是浏览器IE10造成的。
以上来自于百度翻译 以下为原文 Hi Bob I have not see this error ever before. Your description window seems can not do drag and expand. You have many limitation for browser, that I can't help it. On other articles, You said Abuse link was dead but still my browser shows that button. Maybe this cause from browser IE10 too. |
论坛软件问题,据我所知,100%缺乏
对论坛撰稿人的回应: 只能导致论坛的放弃。我这么说的原因很简单, 现在,他们将更加努力地支持柏树客户。 论坛,时间是$$,更不用说挫折因素了。 具体地说- 1)编辑PSPoeRealServer允许的帖子的能力。 2)论坛监督员没有像埃里克那样在PSoCeDealServer上清除广告、黑客等。 3)论坛软件是HTML的承诺,但大部分的功能不起作用, 喜欢剪切和粘贴。 4)举报滥用按钮从未回应,现在似乎不起作用。 只是一个思想撰稿人,是时候给T.J. Rogers写封信了吗?或 引导人们进入PSoCeCurraveCo? 问候,Dana。 以上来自于百度翻译 以下为原文 The forum software problems, and as near as I can tell, the 100% lack of response to forum contributors comments on this issue not responded to, can only lead to abandonment of the forum. The reason I say this is simple, its now taking a great more effort to support Cypress customers on these forums, and time is $$, let alone the frustration factor. Specifically - 1) In-ability to edit a post like psocdeveloper.com allows. 2) Forum overseer not clearing ads, hacks, etc like Eric does at psocdeveloper.com 3) The promise of the forum software to be HTML, but most of the functions do not work, like cut and paste. 4) Report Abuse button never responded to, and now seems to not work. Just a thought contributors, time to compose a letter to T.J. Rogers on this ? or direct people to psocdeveloper.com ? Regards, Dana. |
这两件事就像是柏树负责人的一记耳光。不这样做就像是在我们脸上打一巴掌…鲍勃
以上来自于百度翻译 以下为原文 Well, both is like a slap in the face of the responsible persons at Cypress. Not to do that is like a slap in our face... Bob |
事实上,我认为建设性审查是一种进步。
不仅是用户,而且是对站点负责的人员。也许他们的手 资金是明智的,也许不是。但在这两种情况下,一个论坛运行 这对所有人都是有益的。 问候,Dana。 以上来自于百度翻译 以下为原文 Actually I take the viewpoint that constructive review is progress for not only the users but the staff responsible for the site. Maybe their hands are tied funding wise, or maybe not. But in either case a forum running as it should is a benefit to all. Regards, Dana. |
你有没有尝试清理你的缓存文件(“临时Internet文件”在伊江)?
当我查看这个问题时,FCKddor(用于实现这个HTML编辑器的模块)没有正确下载(Ajax)清理缓存或刷新页面几次解决了这个问题。 以上来自于百度翻译 以下为原文 Have you tried cleaning your cache files ("Temporary Internet Files" in IE)? When I looked into the issue it was the FCKeditor (the module used to implement this HTML editor) not being properly downloaded ( ajax ) Cleaning the cache or refreshing the page solved the issue several times. |
是的,当然,我重置IE,清空缓存,清理cookies并删除所有附加组件。没什么帮助。鲍勃
以上来自于百度翻译 以下为原文 Yes, of course I reset ie, emptied the cache, cleaned the cookies and removed all add-ons. Nothing helped. Bob |
只有小组成员才能发言,加入小组>>
741个成员聚集在这个小组
加入小组2006 浏览 1 评论
1768 浏览 1 评论
3555 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1698 浏览 6 评论
1468 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
284浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
180浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
358浏览 2评论
300浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
492浏览 2评论
GMT+8, 2024-9-25 02:38 , Processed in 0.945887 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
