电子发烧友论坛|
嗨,我有以下问题:
我稍微修改了CyPress提供的拖缆(CPP版本)的例子,以便启动我的流媒体设备(高带宽的大容量)。 我没有任何问题,只要有1个设备附在主机上,只有1个实例在同一个主机上运行。如果我启动拖缆应用程序的2个实例,它们都能够打开同一个FX3设备并与IF进行通信(这显然会造成很多不一致性)。 我预计,一个UBB设备只能打开一次,并且不可能(通过设计)另一个程序开始“干扰”当前正在使用的设备。这不是CyAPIILB的情况吗? 塞浦路斯预见到了哪种机制来保护打开和使用的FX3设备? 如何使设备访问独占? 谢谢,Joebre 以上来自于百度翻译 以下为原文 Hi, I've the following issue: i modified slightly the Cypress provided Streamer (CPP version) example in order to start my streaming device ( High Bandwidth bulk in). I don't have any problem as long as there is 1 only device attached to the host AND 1 only instance of the streamer running on the same host. If I start 2 instances of the Streamer application they are both able to open the same FX3 device and to communicate with if (which obviously creates a lot of inconsistencies). I would expect that that a USBDevice can be opened only once and that it isn't possible (by design) that an other program starts to "interfere" with a device currently in use. Isn't this the case for CyAPI.lib ? Which kind of mechanism has been foreseen by Cypress to protect a opened and used FX3 Device ? How do I make the device access exclusive ? Thanks, Joebre |
4个回答
嗨,你试过了吗?HTTP://www. CyPress?COM/?ID=4和;RID=40554
当做, 阿南德 以上来自于百度翻译 以下为原文 Hi, Have you tried this? http://www.cypress.com/?id=4&rID=40554 Regards, Anand |
谢谢,但在大多数情况下,这不是一个可以接受的解决方案。典型地,可以连接两个或多个相同类型的设备(EX 2或3凸轮)。同一应用程序的2个实例应该能够通过设计来打开不同的凸轮并与它们交互而不产生问题或干扰它们自身。
塞浦路斯用哪种机制来克服这个问题? 谢谢,乔尔 以上来自于百度翻译 以下为原文 Thanks but this isn't a acceptable solution in most of the cases. Typically one could attach two or more devices of the same type (ex 2 or 3 cams). 2 instances of the same Application should be able by design to open different Cams and interact with them without generating problems or interfere between them self. Which kind of mechanism is Cypress using for overcome this problem ? Thanks, Joel |
嗨,乔,
我所提供的KB文章也能达到同样的效果。一旦打开句柄,特定设备就不会对其他应用程序可见。句柄关闭后,其他应用程序也可见。 如果这样的特性需要用除此之外的方法来实现,则驱动程序必须维护一个变量来表示这个(Cy***.系统一个实例,而不管连接到它的设备的数量,而不是CyAPI.LIB的情况),并将其提供给CyAPI.lib。还有一大堆需要讨论和理解的场景。请创建一个技术支持的细节,为什么你需要这个特点,什么是需要满足的具体场景。这样我们的团队可以在内部讨论并找出需要做的事情。当做, 阿南德 以上来自于百度翻译 以下为原文 Hi Joe, The KB article that I provided is capable of acheiving the same. Once a handle is opened that particular device will not be visible to other applications. After the handle is closed it will be visible to other applications too. If a feature like this needs to be implemented in a method other than that, the driver has to maintain a variable to represent this (CyUSB.sys one instance irrespective of number of devices connected to it, not the case for CyAPI.lib) and provide that to CyAPI.lib. There are also a whole bunch of scenarios that need to be discussed and understood. Please create a tech support with details on why you need this feature and what are the specific scenarios that need to be met. This way our team can internally discuss and figure out what needs to be done. Regards, Anand |
嗨,这不正确。我添加了“独家”注册表条目,你告诉我,我得到以下行为:
只有一个CyPress设备(我认为排他性与使用CyPress驱动程序的设备有关)即使在它们有不同的PIDs(EX:BooT和Turror固件)时也是可见的。Windows 7设备管理器告诉:“Windows无法加载硬件的设备驱动程序,因为设备驱动程序的前一个实例仍在内存中。(代码38)当我移除2个设备中的一个(例如,具有不同的PID)时,剩余的设备能够将驱动程序加载到存储器中。这意味着在您的修改(Windows 7 64位OS)下,只有一个设备可以使用。这个诅咒解决了并发访问特定设备的问题,因为它只允许在系统上存在1个设备,但我认为您可以同意这不是专业产品可接受的解决方案。 目标场景非常简单,一旦他们出售基于FX3的产品,就会发生在每个人身上。我有两个相同的USB 3产品(相同的PID和VID,可能只有序列号是不同的)。然后将两个设备连接到PC的USB 3树上。人们期望的是,相同或不同应用的两个实例能够打开并使用两个FX3设备中的一个。这两个应用程序不可能使用同一个FX3设备打开广告(不是吗?). 在MS Windows下,不可能打开和使用给定的串行端口两次。我也期望USB设备也有同样的行为。我希望共享机制能够在比驱动程序更高的层次上实现。 我需要的是一种机制,它允许我以一种排他性的方式处理2个基于FX3的设备,它们同时连接到同一台主机PC。它们都可用。 最好的问候,JoeBre 以上来自于百度翻译 以下为原文 Hi, this isn't correct. I added the "exclusive" registry entry which you told me and I got the following behaviour: only one Cypress device ( I suppose that exclusivity is related to devices which are using the Cypress driver) is visible at the time even if they have different PIDs (ex: boot and streamer firmware). The windows 7 device manager tells: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)". As soon as I remove one of the 2 devices (which for instance have different PID) the remaining device is able to load the driver into the memory. This means with your modification (under Windows 7 64 bit OS) only one device can be in use. This of curse solves the issue of concurrent access to a particular device since it allows only 1 device to be present on the system, but I think you can agree that this isn't an acceptable solution for a professional product. The target scenario is very simple and is going to happen to everybody as soon as they sell an FX3 based product. I have two identical USB 3.0 products (Same PID and VID, maybe only the serial number is different). Both devices are then connected to the USB 3.0 tree of a PC. What one would expect is that two instances of the same or a different application are able to open and use one of the two FX3 devices. It shouldn't be possible that the two applications are opening ad using the SAME FX3 device (isn't it?). Under MS windows it isn't possible to open and use twice a given serial port. I would expect the same behaviour also for a USB device. I would expect a sharing mechanism to be implemented at a higher level than the driver. What I need is a mechanism which allows me to handle in an exclusive manner 2 FX3 based devices both connected at the same time to the same host PC. Both of them shall be usable. Best regards, JoeBre |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7347 浏览 0 评论
2485 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7851浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6413浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
757浏览 2评论
729浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8260浏览 2评论
/9
GMT+8, 2025-12-13 20:44 , Processed in 0.799741 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2884
