亲爱的朋友们,
我是柏树领域的新手。现在我应该熟悉如何尽快使用UB3 DVK。 现在我阅读了EZ-USB FX3开发工具包快速入门指南.PDF来启动我的项目,SDK已经安装成功了。 但是,我不知道如何安装DVK的驱动程序,因为当我插入UN电缆时,在我的计算机中没有通知,当我打开硬件管理中心时,在UB3树中没有其他设备。 你能告诉我如何安装FX3 DVK的驱动程序吗? 谢谢! 以上来自于百度翻译 以下为原文 Dear guys, I am a newer in cypress field . And now I should to familiar with how to use USB3 DVK as quickly as possible. Now I read the EZ-USB FX3 Development Kit quick start-guide.pdf to start my project , and the sdk have been installed in sucess. however, I do not know how to install the DVK' s driver , because when I plugin the USN cable , there are no notice in my compurer , and when I open the hardware managment center , there are no other devices in USB3 tree. Can you tell me how to install the FX3 DVK 's driver ? Thanks! |
2个回答
亲爱的Manas,
如果USB插件的LED是,我已经同意,在我的PC,有“1.2 驱动”文件夹下的“程序文件 CyPress文件夹”。 但是,如果我插入或退出USB电缆,对PC的“设备管理器”没有影响,我们知道如果PC识别USB设备,“设备管理器”将刷新,如果设备插件! 我找不到关于如何使用DVK板和如何设置软件环境的指南,这样开发人员就可以开发固件、应用程序等等。所以当我打开位于你的USB套件中的Eclipse IDE并加载CysBueSub的例子时,有很多错误,似乎在SW环境中有错误! 谢谢! 以上来自于百度翻译 以下为原文 Dear Manas, If the USB plugin the LED is on , and I have confired that in my PC there are have "1.2driver" folder under the "programm filescypress folder " . But If I plugin or out the USB Cable , there are no effects on the PC 's "devices manager" , we know if the PC indentify a USB device, the "devices manager " will refresh if the device plugout ! I can not find the guide about how to use the DVK board and how to set the software environment so developers can develop the firmware .application and so on .... So when I open the eclipse IDE which located in your USBSuite and loaded the CyUSBSuite example , there are a lot of errors , It seems that there are errors in SW environment ! Thanks! |
非常感谢您更新线程。
当做, 西克里希纳。 以上来自于百度翻译 以下为原文 Thanks a lot for updating the thread. Regards, sai krishna. |
只有小组成员才能发言,加入小组>>
742个成员聚集在这个小组
加入小组2011 浏览 1 评论
1773 浏览 1 评论
3561 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1705 浏览 6 评论
1473 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
313浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
216浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
363浏览 2评论
303浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
502浏览 2评论
GMT+8, 2024-9-29 04:55 , Processed in 0.887158 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
