电子发烧友论坛|
嗨,
我已经测试了20多个设计用于L6926稳压器的电路板,发现一些稳压器突然进入热关断模式。我认为它是热关机,因为它试图恢复生命,加热并在一秒钟内再次关闭。在允许一定的冷却时间后芯片通电时重复相同的操作。从稳压器汲取的电流仅为几mA(最大10mA)。 在未能理解这种失败之后,我们提供了并联线性稳压器。现在,每次我们使用DC DC稳压器发生故障时,我们只需将其拆下并安装线性稳压器即可。线性稳压器从未在船上失效。所以我确信这不是负载问题。过去几个月我一直在看这些失败。 是否有任何测试方法可供您理解此故障。我尝试使用比推荐值(6.8uH)更低的电感值(4.7uH),并且故障与两个电感值一样普遍。 你能推荐一个更稳定的更换零件吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have tested over 20+ boards that was designed to take L6926 regulators and find that some of the regulators abruptly go into thermal shutdown mode. I think it is thermal shutdown because it tries to spring back to life, heats up and shuts down again in a matter a second. The same repeats when the chip is powered up after allowing a certain cooling time. The currents being drawn from the regulators is only a few mA (10mA max). After failing to understand this failure, we made provision for a parallel linear regulator. Now, each time we have a failure with the DC DC regulator, we just remove it and mount the linear regulator. The linear regulators have never failed on board. So I am certain that this is not a load issue. I have been seeing these failures over the last several months. Is there any test method you would recommend for understanding this failure. I have tried using a lower value of inductance (4.7uH) than the recommended (6.8uH) value and the failures are just as common with both inductor values. Could you recommend a more stable replacement part? Thanks. |
1个回答
嗨,
你可以发送你的设置吗? 我们需要知道Vin,Vout,电流负载以及PCB布局...... 问候 文森佐 以上来自于谷歌翻译 以下为原文 Hi, could you please send your setup? we need to know Vin, Vout, Current Load and also a PCB layout... Regards Vincenzo |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
748浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
727浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
771浏览 5评论
/9
GMT+8, 2025-12-12 03:43 , Processed in 0.599684 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1785
