电子发烧友论坛|
亲爱的SIRSI希望使用PIN RC1上的PWM。我没有工作,这张照片(我试过2天了)。我当然使用MCC和数据表。PSS2AC低;CCP2AS禁用;ECCP2AS=0x00;//P2RSEN自动_重启;P2DC 0;PWM2CON=0x80;//PWM2CON=0x80;//PWM2CON=0X2CON=0x80;//STRM2STRM2CON P2D_2P2D_to_端口;STR2C P2C P2C_P2C_2C_to_端口;STR2C P2C_P2C_P2C_to_端口;STR2B P2B_P2B_to_端口;STR2A P2B P2B_P2B_P2B_to_端口;STR2A P2B P2A_to_端口;STR2A P2A_开始_端口;STR2SYNC start start_start_CCPR2H=0x00;通知MUX PINS设置正确:#pragma config CCP2MX=PORTC1//CCP2 MUX bit->CCP2输入/输出与RC1#pragma config PBADEN=ON//PORTB A/D Enable bit->PORTB<5:0>pins被配置为复位#pragma c上的模拟输入通道onfig CCP3MX=PORTB5//P3A/CCP3多比特->P3A/CCP3输入/输出与RB5#pragma config HFOFST=ON//HFINTOSC快速启动>HFINTOSC输出多路复用,并且就绪状态不被振荡器稳定状态#pragma config T3CMX=PORTC0//timer3时钟输入多比特->T3CKI i延迟s在RC0#pragma配置P2BMX=PORTC0//ECCP2 B上输出多路位->P2B在RC0#pragma配置MCLRE=EXTMCLR//MCLR Pin Enable bit->MCLR pin启用,RE3输入pin禁用设置定时器4:void TMR4_Initialize(void){//将TMR4设置为在用户接口//T4CKPS 1:1;T4O中选择的选项UTP1:4;TMR4ON;T4CON= 0x18;//PR4 249;PR4= 0xF9;//TMR4 0;TMR4= 0x00;/ /清除IF标志。PIR5bits.TMR4IF=0;//Start TMR4 TMR4_StartTimer();}使用XC08实际转换与PIckit3。请帮助我,否则我会变态。谢谢Andy
以上来自于百度翻译 以下为原文 Dear Sirs I want to use the PWM on PIN RC1. I did it not working, this lausi PIC (-; (i tried 2 days now). I use the MCC and the Datasheet of course. Following Setting: INitialising PWM2: void EPWM2_Initialize (void) { // Set the PWM to the options selected in MPLAB(c) Code Configurator // CCP2M P2A,P2C: active low; P2B,P2D: active high; DC2B 3; P2M0 single; CCP2CON = 0x3E; // CCP2ASE operating; PSS2BD low; PSS2AC low; CCP2AS disabled; ECCP2AS = 0x00; // P2RSEN automatic_restart; P2DC 0; PWM2CON = 0x80; // STR2D P2D_to_port; STR2C P2C_to_port; STR2B P2B_to_port; STR2A P2A_to_port; STR2SYNC start_at_begin; PSTR2CON = 0x00; // CCPR2L 124; CCPR2L = 0x7C; // CCPR2H 0; CCPR2H = 0x00; // Selecting Timer4 CCPTMRS0bits.C2TSEL = 0x1; } Noticed the MUX PINS Set correct: #pragma config CCP2MX = PORTC1 // CCP2 MUX bit->CCP2 input/output is multiplexed with RC1 #pragma config PBADEN = ON // PORTB A/D Enable bit->PORTB<5:0> pins are configured as analog input channels on Reset #pragma config CCP3MX = PORTB5 // P3A/CCP3 Mux bit->P3A/CCP3 input/output is multiplexed with RB5 #pragma config HFOFST = ON // HFINTOSC Fast Start-up->HFINTOSC output and ready status are not delayed by the oscillator stable status #pragma config T3CMX = PORTC0 // Timer3 Clock input mux bit->T3CKI is on RC0 #pragma config P2BMX = PORTC0 // ECCP2 B output mux bit->P2B is on RC0 #pragma config MCLRE = EXTMCLR // MCLR Pin Enable bit->MCLR pin enabled, RE3 input pin disabled Setting Timer 4: void TMR4_Initialize(void) { // Set TMR4 to the options selected in the User Interface // T4CKPS 1:1; T4OUTPS 1:4; TMR4ON off; T4CON = 0x18; // PR4 249; PR4 = 0xF9; // TMR4 0; TMR4 = 0x00; // Clearing IF flag. PIR5bits.TMR4IF = 0; // Start TMR4 TMR4_StartTimer(); } Using XC08 actual VErsion with PIckit3. Please help me, otherwise i get freaky. Thanks Andy |
2个回答
对不起,双柱。我必须学习论坛如何工作(-;
以上来自于百度翻译 以下为原文 Sorry for double post. I have to learn how the forum works (-; |
相关或相同:http://www. McCyp.com / .RUM/M954 716.ASPX·954716
以上来自于百度翻译 以下为原文 related or same: http://www.microchip.com/.rums/m954716.aspx#954716 |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 07:40 , Processed in 1.062806 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2098
