电子发烧友论坛|
嗨,大家好
我是新成员...... :))) 我设计了一个简单的板来编程我的FPGA(xc3s400-5tq144),但我不确定它是否可行。 问题是:将xcf02放在电路板(朝向FPGA)的位置是否重要,我的意思是,我是否必须将它们放在附近或者它们更好地放置在远处? 以上来自于谷歌翻译 以下为原文 Hi everyone I'm new member....:))) I designed a simple board to programming my FPGA(xc3s400-5tq144),but I'm not sure it would works. Question is : is it important where I put xcf02 on the board(toward FPGA) , I mean , do I have to put them nearby or it better located them in far ? |
3个回答
增加FPGA和XCF02S之间的距离并不是更好。
然而,在合理的范围内,增加的距离不应该引起问题。 如果您可以选择,较短的信号走线优于较长的信号走线。 如果你正在设计一个新的董事会,你为什么要使用Spartan-3和XCF02S而不是的Spartan-3A(或Spartan-3E)和便宜,易得(多源)SPI闪存,并不需要JTAG更新呢? - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 It is NOT better to increase the distance between the FPGA and the XCF02S. Within reason, increased distance should not cause a problem, however. If you have a choice, shorter signal traces are better than longer signal traces. If you are designing a new board, why would you use Spartan-3 and XCF02S rather than Spartan-3A (or Spartan-3e) and cheap, readily available (multi-sourced) SPI flash memory which does not need JTAG for updating it? -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
这项工作是我的大学项目,我不能改变FPGA,我将在下一个项目中使用spartan-3E。
无论如何,谢谢你的帮助.. :))) 以上来自于谷歌翻译 以下为原文 This work is my university project and i can't change the FPGA , I will use spartan-3E in my next project. anyway thanks for your help..:))) |
价格和可用性不是大学项目的优先考虑因素。 事实上,我不鼓励在下一个项目中从Spartan-3改为Spartan-3e。 一旦您完成了工作设计,为什么要引入更多变化和风险? 设计工程中最重要的规则之一是:如果没有破坏,请不要修复它。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 This work is my university project and i can't change the FPGA, I will use spartan-3E in my next project. Price and availability is not a priority concern for university projects. In fact, I would discourage a change from Spartan-3 to Spartan-3e on the next project. Why introduce more change and risk, once you have achieved a working design? One of the most important rules in design engineering is: If it is not broken, do not fix it. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 23:53 , Processed in 0.565478 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1999
