电子发烧友论坛|
先生
我有一个FX3超高速设计的问题,它让我困惑了两个星期,所以请帮助我。 在我的设计中,我使用的是MyyStoto1 DMA通道,它有2个有效的套接字,每个套接字都有4个有效的缓冲区,我的问题是每次启动一个新的传输时,在8个缓冲器传输之后,总是丢失随机数据,另外,我所接收的数据是连续的。我确信FPGA总是比PC接收数据晚些时候发送数据。 以上来自于百度翻译 以下为原文 Dear Sir I get a problem of my FX3 superspeed design, and it has confused me for two weeks, so please help me. In my design I use many_to_one DMA channel which has 2 valid socket and every socket has 4 valid buffers,my problem is everytime I start a new transfer I always lose random data after 8buffers have transfered,beside this my data received is continuous. I am sure that FPGA always sends data a little later than PC receives data. |
2个回答
你好,
我不清楚你的问题。请同样帮助我。 以下是您的设置: FPGA ->FX3在端点-Gt;PC. FX3中有8个缓冲区,用于将数据从FPGA传输到PC.,当你读取前8个缓冲区时,你得到正确的数据吗?在前8个缓冲区之后,您没有收到正确的数据吗?. 请告诉我数据模式日志,如果可能的话。 谢谢, Sai Krishna。 以上来自于百度翻译 以下为原文 Hi, I did not understand your problem clearly. Please help me in the same regard. Following is your setup: FPGA --> FX3 IN endpoint -->PC. You have total 8 buffers in FX3 allocated for transferring data from FPGA to PC. Are you getting the right data when you are reading the first 8 buffers? Are you not receiving the right data after first 8 buffers?. Please show me the data pattern logs, if possible. Thanks, Sai Krishna. |
喜赛
谢谢你的答复,你明白我的意思,我得到正确的数据,当我读前8个缓冲器和ANI收到正确的数据后,前8个缓冲区,但在这两个阶段,我失去的数据从FPGA转移约1ms或更多,就像普鲁兹遇到在HTTP://wwwyCysP.com /?APP =论坛和ID ID=167和RID=63294, 谢谢你的帮助 朱 以上来自于百度翻译 以下为原文 Hi Sai Thank you for reply,and you get my point,I get the right data when I am reading the first 8 buffers and I receive the right data after first 8 buffers,but between this two stage I lose data transfered from FPGA for about 1ms or more just like ProHerz encountered in http://www.cypress.com/?app=forum&id=167&rID=63294, Thank you for help Zhu |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 15:22 , Processed in 0.652201 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
285
