你好 -
我看到了Spartan 6设计的问题,我在其中实例化了FIR编译器核心。 使用Chipscope,我能够看到输出信号按预期运行,但经过一段时间(10-20秒)后,输出信号变为随机常数值,“准备好数据”信号保持低电平。 不同Spartan 6board上的相同代码(相同的位文件)(相同的FPGA,使用相同的I / O,但安装了不同的备用外设),每次都能产生正确的结果。 我的第一个想法是电源问题(掉电等),但在确定供电范围后,它们非常干净,配置后似乎根本没有下降。 有没有人见过类似FIR滤波器停止响应的地方? 谢谢!! 亚当 以上来自于谷歌翻译 以下为原文 Hello - I'm seeing an issue with a Spartan 6 design where I have a FIR compiler core instantiated. Using Chipscope, I'm able to see the output signals performing as expected, but after some time (10-20 seconds) the output signal becomes a random constant value and the "ready for data" signal stays low. The same code (same bit file) on a different Spartan 6 board (same FPGA, same I/O used, but different alternate peripherals installed), produces correct results every time. My first thought goes to power issues (brown out, etc.), but after scoping the supplies, they are very clean and don't seem to dip at all after configuration. Has anyone seen anything similar where a FIR filter stops responding? Thanks!! Adam |
4个回答
是的 - 时钟速度为65.536MHz,我们正在满足时间限制。
谢谢 以上来自于谷歌翻译 以下为原文 Yes - the clock speed is at 65.536MHz, and we are meeting timing with that constraint. Thanks |
亚当,
你有筹码观察过滤器的输入吗? 这是做什么的? 也许触发并查看驱动它的逻辑是否重置,例如? 〜基思 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 hi Adam, have you got chipscope observing the input to the filter? What is this doing? Maybe trigger and see if the logic driving this is reset for example?? ~Keith ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
对我来说,它似乎仍然是一个与时间相关的问题。
你确定所有的输入都是 FIR内核与时钟同步? 他们中的任何一个都来自片外而没有 首先通过FPGA内部的触发器? 如果是这样,你有没有OFFSET 对这些投入的限制? 请记住,PERIOD约束只检查内部 翻牌到翻牌圈。 - Gabor - Gabor 以上来自于谷歌翻译 以下为原文 It still seems like a timing-related issue to me. Are you sure that all of the inputs to the FIR core are synchronous to the clock? Do any of them come from off-chip without first going through a flip-flop inside the FPGA? If so, do you have OFFSET IN BEFORE constraints on these inputs? Remember that PERIOD constraints only check internal flop to flop paths. -- Gabor -- Gabor |
只有小组成员才能发言,加入小组>>
2415 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3372 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2458 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1089浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
579浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
441浏览 1评论
2000浏览 0评论
723浏览 0评论
GMT+8, 2024-12-20 19:11 , Processed in 1.385295 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
