嗨,
为了调试系统,我需要在系统运行时动态读取Block-RAM内容.... 我只有JTAG线,我不能在FPGA中制作一个特定的块用于读取内容并通过JTAG等发送它们。 我可以使用ISMP 13.2作为工具iMPACT。 使用标准的JTAG工具有没有办法做到这一点? 当然,我现在认为读取需要时间,RAM的内容不会连贯......但那是我的问题...... 谢谢 以上来自于谷歌翻译 以下为原文 Hi, For debugging a system, I need to read Block-RAM contents dynamically, while the system is running.... I have only JTAG lines, and I can not make a specific block in the FPGA for reading the contents and send them via JTAG or whatever. I can use as tools iMPACT with ISE 13.2. Is there any way to do that using the standard JTAG tools? Of course, I now that the read will take time and that the contents of the RAM will not be coherent... but that’s my problem... Thanks |
3个回答
在设计运行时通过JTAG读回BRAM可能会破坏BRAM内容。
您需要通过发出SHUTDOWN命令来停止设计,在读回期间禁用对BRAM的读写操作。 UG332中有一个JTAG回读程序 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf 要专门回读BRAM,您需要将FAR设置为特定的BRAM loaction。 iMPACT不提供此功能,因此您需要开发自己的JTAG控制器或自定义SVF文件来执行此操作。 这不是调试设计的好方法。 我强烈建议您使用我们的调试工具(如ChipScope)进行系统调试或使用Simulation来调试您的设计。 通过JTAG回读BRAM将有很多努力来获得有限的回报。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Reading back BRAM over JTAG while your design is running will potentially corrupt the BRAM content. You would need to stop the design either by issuing a SHUTDOWN command OR disabling read and writes to your BRAM during readback. There is a JTAG readback procedure in UG332 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf To specifically read back BRAM you would need to set the FAR to the specific BRAM loaction. iMPACT does not provide this capability so you would need to develop your own JTAG contoller or customize an SVF file to do this. This is not a good route to debug your design. I would STONGLY recommend that you use our debug tools such as ChipScope for in system debug or Simulation to debug your design. Reading back BRAM over JTAG will be alot of effort for limited return. View solution in original post |
您需要通过发出SHUTDOWN命令来停止设计,在读回期间禁用对BRAM的读写操作。 UG332中有一个JTAG回读程序 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf 要专门回读BRAM,您需要将FAR设置为特定的BRAM loaction。 iMPACT不提供此功能,因此您需要开发自己的JTAG控制器或自定义SVF文件来执行此操作。 这不是调试设计的好方法。 我强烈建议您使用我们的调试工具(如ChipScope)进行系统调试或使用Simulation来调试您的设计。 通过JTAG回读BRAM将有很多努力来获得有限的回报。 以上来自于谷歌翻译 以下为原文 Reading back BRAM over JTAG while your design is running will potentially corrupt the BRAM content. You would need to stop the design either by issuing a SHUTDOWN command OR disabling read and writes to your BRAM during readback. There is a JTAG readback procedure in UG332 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf To specifically read back BRAM you would need to set the FAR to the specific BRAM loaction. iMPACT does not provide this capability so you would need to develop your own JTAG contoller or customize an SVF file to do this. This is not a good route to debug your design. I would STONGLY recommend that you use our debug tools such as ChipScope for in system debug or Simulation to debug your design. Reading back BRAM over JTAG will be alot of effort for limited return. |
只有小组成员才能发言,加入小组>>
2180 浏览 7 评论
2618 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
453浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2186浏览 0评论
516浏览 0评论
1659浏览 0评论
GMT+8, 2024-5-15 19:03 , Processed in 1.041906 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
