电子发烧友论坛扫一扫,分享给好友
两个完全对称的任务只是传入一个参数选择两组数据两个任务运行时要调用一个AD采样函数现在出现的问题是一个任务开始采样后另一个一开始第一个任务采样就停了
void Task_Power1() { Task_Power(0); } void Task_Power2() { Task_Power(1); } void Task_Power(u8 chx) 两个任务运行后是阻塞的 |
3个回答
AD采用能2个任务同时进行么?
正因为不行才出现问题了能不能用信号量邮箱来互斥呢就是当一个任务占用AD时不允许其他任务使用只有这个任务释放AD才能使用
请原子大哥指点
u16 ADCColl(u8 channel,u8 i){ //FeedDog(); if(i<16)chselect(i); ADC_ClearFlag(ADC1, ADC_FLAG_EOC); ADC_RegularChannelConfig(ADC1, channel, 1, ADC_SampleTime_239Cycles5); ADC_SoftwareStartConvCmd(ADC1, ENABLE); while(!(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC))); ADC_ClearFlag(ADC1, ADC_FLAG_EOC); return ADC_GetConversionValue(ADC1); }这是那个被两个任务调用的函数 void RefreshData(char channelx){ u16 i,ADch,tmp1; s16 temp; u32 ADsum[ADNUM2]; OSTimeDlyHMSM(0, 0, 0, 300); for(ADch = CH1ADB1; ADch < ADNUM2; ADch++){ ADsum[ADch] = 0;} for(i = 0; i < ADSAMP_NUM; i++) { if(channelx==0) { for(ADch = CH1ADB1; ADch < CH2ADB1; ADch++) { ADsum[ADch] += ADCColl(channel[ADch],ADch);//(enum ADCHANNELX) } } if(channelx==1) { for(ADch = CH2ADB1; ADch < DCVIN; ADch++) { ADsum[ADch] += ADCColl(channel[ADch],ADch);//(enum ADCHANNELX) } } for(ADch = DCVIN; ADch < ADNUM2; ADch++) { ADsum[ADch] += ADCColl(channel[ADch],ADch);//(enum ADCHANNELX) } } for(ADch = CH1ADB1; ADch < ADNUM2; ADch++){ ADsum[ADch] /= ADSAMP_NUM; } switch(channelx) { case 0: for(i = CH1ADB1; i < CH1DCC; i++){ run[channelx].VB[i+1] = COVER_B16(ADsum);//*CALIVOL/calivalue; if(run[channelx].VB[i+1] < 500) run[channelx].VB[i+1] = 0; } temp = COVER_CC(ADsum[ADCUR1]); //if((temp > 10)&&(temp < 1000))temp -= (run.SCC*(10-temp/100)/10); run[channelx].CC = temp/* * CALICC/calivalue[ADCUR1] */- run[channelx].SCC;////屏蔽校准 if(run[channelx].CC < 10)run[channelx].CC = 0; run[channelx].DC = COVER_DC(ADsum[CH1DCC]) - run[channelx].SDC;//)*CALIDC/calivalue[ADDC]; if(run[channelx].DC < 10)run[channelx].DC = 0; run[channelx].VIN = COVER_BPNI(ADsum[DCVIN]); if(run[channelx].VIN < 50)run[channelx].VIN = 0; run[channelx].VOUT= (COVER_BPNI(ADsum[CH1BV])/**CALIVOL*4/calivalue[CH1BV]*/) - (run[channelx].CC/ 100);////屏蔽校准 if(run[channelx].VOUT < 50)run[channelx].VOUT = 0; tmp1 = COVER_NTCV(ADsum[ADNTC1]);//求电压 tmp1 = COVER_NTCR(tmp1);//求电阻 run[channelx].NTC = COVER_NTC((float)tmp1/1000);//求温度 if((run[channelx].NTC < -10)||(run[channelx].NTC > 100)) ///run[channelx].NTC = -100; run[channelx].NTC = 30; tmp1 = COVER_NTCV(ADsum[ADBT1]);//求电压 tmp1 = COVER_NTCR(tmp1);//求电阻 run[channelx].BNTC = COVER_NTC((float)tmp1/1000);//求温度 if((run[channelx].BNTC < -10)||(run[channelx].BNTC > 100)) ///run[channelx].BNTC = -100; run[channelx].BNTC = 30; break; case 1:for(i = CH2ADB1; i < CH2DCC; i++){ run[channelx].VB[i-7] = COVER_B16(ADsum);//*CALIVOL/calivalue; if(run[channelx].VB[i-7] < 500) run[channelx].VB[i-7] = 0; } temp = COVER_CC(ADsum[ADCUR2]); //if((temp > 10)&&(temp < 1000))temp -= (run.SCC*(10-temp/100)/10); run[channelx].CC = temp /** CALICC/calivalue[ADCUR2]*/ - run[channelx].SCC; if(run[channelx].CC < 10)run[channelx].CC = 0; run[channelx].DC = COVER_DC(ADsum[CH2DCC]) - run[channelx].SDC;//)*CALIDC/calivalue[ADDC]; if(run[channelx].DC < 10)run[channelx].DC = 0; run[channelx].VIN = COVER_BPNI(ADsum[DCVIN]); if(run[channelx].VIN < 50)run[channelx].VIN = 0; run[channelx].VOUT= (COVER_BPNI(ADsum[CH2BV])/**CALIVOL*4/calivalue[CH2BV]*/) - (run[channelx].CC/ 100); if(run[channelx].VOUT < 50)run[channelx].VOUT = 0; tmp1 = COVER_NTCV(ADsum[ADNTC2]);//求电压 tmp1 = COVER_NTCR(tmp1);//求电阻 run[channelx].NTC = COVER_NTC((float)tmp1/1000);//求温度 if((run[channelx].NTC < -10)||(run[channelx].NTC > 100)) ///run[channelx].NTC = -100; run[channelx].NTC = 30; tmp1 = COVER_NTCV(ADsum[ADBT2]);//求电压 tmp1 = COVER_NTCR(tmp1);//求电阻 run[channelx].BNTC = COVER_NTC((float)tmp1/1000);//求温度 if((run[channelx].BNTC < -10)||(run[channelx].BNTC > 100)) ////run[channelx].BNTC = -100; run[channelx].BNTC = 30; break; default: break; } FANProc(); } 这是调用AD转换的函数 |
只有小组成员才能发言,加入小组>>
1018 浏览 1 评论
1849 浏览 0 评论
1830 浏览 1 评论
3254 浏览 5 评论
3581 浏览 9 评论
1021浏览 1评论
1850浏览 1评论
如何知道嵌入式电子控制单元 (ECU) 中的RAM使用情况?
1360浏览 1评论
1852浏览 0评论
1178浏览 0评论
/9
GMT+8, 2025-12-2 03:44 , Processed in 0.472740 second(s), Total 48, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3692
