电子发烧友论坛扫一扫,分享给好友
SMSC表说
他的意思是接收数据有效吗? 的情况下 TX_EN I: - 发送使能:表示显示有效数据 在TXD [3:0]信号上,用于传输。 它非常清楚,但RXDV令人困惑 以上来自于谷歌翻译 以下为原文 The SMSC sheets says What he means by receive data valid?? In case of TX_EN I:- Transmit Enable: Indicates that valid data is presentedon the TXD[3:0] signals, for transmission. It is very much clear but RXDV is confusing |
2个回答
这是您连接到接收数据FIFO(在FPGA中)上的WR_EN引脚的信号。
就像TX_EN告诉PHY在TX_D信号上有有效数据进行传输一样,RX_DV告诉MAC(FPGA)RX_D信号上有有效的接收数据供MAC处理。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 That's the signal you connect to the WR_EN pin on the receive data FIFO (in the FPGA). Just as TX_EN tells the PHY that there is valid data on the TX_D signals for transmission, RX_DV tells the MAC (FPGA) that there is valid received data on the RX_D signals for processing by the MAC. - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing.View solution in original post |
就像TX_EN告诉PHY在TX_D信号上有有效数据进行传输一样,RX_DV告诉MAC(FPGA)RX_D信号上有有效的接收数据供MAC处理。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 That's the signal you connect to the WR_EN pin on the receive data FIFO (in the FPGA). Just as TX_EN tells the PHY that there is valid data on the TX_D signals for transmission, RX_DV tells the MAC (FPGA) that there is valid received data on the RX_D signals for processing by the MAC. - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:17 , Processed in 0.643504 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
403
