电子发烧友论坛|
任何人都可以告诉我“错误”是什么意思(除了显而易见的!)。
当打开HP3458A或从前面板执行“测试”功能时,我会得到它。 完成ROM和RAM测试以及启动“Slave测试”时会出现“错误”消息。 我有两个3458A,当它放弃时,它说“自我测试失败”; 另一个未能达到“VDC”状态。如果它超出了用户的修复范围,你可以告诉我在哪里需要发送它们才能得到修复,谢谢。谢谢 以上来自于谷歌翻译 以下为原文 Can anyone tell me what "err" means (other than the obvious!). I get it when either turning on HP3458A or when doing a "test" function from the front panel. The "err" message appears when it finishes doing ROM and RAM tests and when it starts the "Slave test". I have two 3458A's one says "self test failed" when it gives up; the other fails to a "VDC" state. If it is beyond the user to fix can you tell me where I need to send them to get fixed, please. Thanks |
2个回答
202硬件故障从机测试AC板并且无法进行V DCThanks
以上来自于谷歌翻译 以下为原文 202 hardware failure slave test AC board and fails to V DC Thanks |
您好Robbie,不幸的是这意味着A2板可能存在问题,即AC转换器组件。
我建议将其发送到安捷伦服务中心进行维修。 美国联系电话是免费电话:+1 800 829-4444按#,然后按3 以上来自于谷歌翻译 以下为原文 Hello Robbie, Unfortunately this means there is probably an issue with A2 board, which is the AC converter assembly. I would suggest sending it in to an Agilent service center for repair. The USA contact number is toll-free: +1 800 829-4444 Press #, then 3 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:51 , Processed in 0.580900 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1427
