电子发烧友论坛|
刚刚在我的戴尔XPS 15笔记本电脑上安装了MPLAB X 3.5,带有4K(3840 x 2160)的显示器;这并不是一次很好的体验,因为图标太小了,以至于我不能分辨它们之间的区别,字体很奇怪,在某些情况下,它们像附带的屏幕截图一样被压扁。是?
以上来自于百度翻译 以下为原文 Just installed MPLAB X 3.5 on my Dell XPS 15 laptop with 4K (3840 x 2160) display; it's not a great experience because the icons are so small that I can't tell the difference between them and fonts are weird, in some cases they are squashed like in the attached screen shot. Any suggestions to fix this? Attached Image(s) |
18个回答
操作系统?也许这有助于-& http://StaskPox.com……e缩放窗口-8
以上来自于百度翻译 以下为原文 OS ? Maybe this helps -> http://stackoverflow.com/...e-scaling-on-windows-8 |
我还有这个问题,谁能给我指出一个解决办法?有人建议更改Netbeans.conf文件会有帮助,但我无法在我的系统上找到该文件,事实上,在Program Files或Program Files(x86)下没有Netbeans文件夹。我运行的Windows 10, 64位与4K显示器(3840×2160)-它是一个戴尔XPS15笔记本电脑。
以上来自于百度翻译 以下为原文 I still have this issue - can anyone point me to a fix? Some suggest that changing the Netbeans.conf file can help but I can't find that file on my system, in fact there's no Netbeans folder under Program Files or Program Files (x86). I'm running Windows 10, 64 bit with a 4k display (3840 x 2160) - it's a Dell XPS15 laptop. |
Microchip MPLABX V3.50MPLABIDIDE等MPLABIDID.COMPHTHTP://MicroChIPDeavic.COM/MPLABX:JVM配置选项
以上来自于百度翻译 以下为原文 MicrochipMPLABXv3.50mplab_ideetcmplab_ide.conf http://microchipdeveloper.com/mplabx:jvm-configuration-options |
好,所以我可以打开mplab_ide.conf,但是没有关于使用系统属性Dsun.java2d.dpi.=true启动NetBeans的内容。任何人都可以通过向mplab_ide.exe添加一行来帮助指定该参数的语法吗?谢谢
以上来自于百度翻译 以下为原文 OK, so I can open mplab_ide.conf but there's nothing in there about starting NetBeans with the system property -Dsun.java2d.dpiaware=true Can anyone help on the syntax for specifying that parameter by adding a line to mplab_ide.exe? Thanks |
我的股票3.51是
以上来自于百度翻译 以下为原文 My stock 3.51 is default_options="-J-Dcrownking.stream.verbosity=very-quiet -J-Xss2m -J-Xms256m -J-Xmx8164m -J-Dapple.awt.graphics.UseQuartz=true -J-XX:+CMSClassUnloadingEnabled -J-Dapt.limit.expanded.params=1000 -J-Dplugin.manager.check.interval=EVERY_STARTUP -J-Dsun.java2d.noddraw=true -J-Dorg.netbeans.modules.extbrowser.UseDesktopBrowse=true" adding this just before the closing " might do what you want or =true if you wish, I used to use this on x 3.26 the fontsize is optional -J-Dsun.java2d.dpiaware=false --fontsize 24 |
Jim,我试过了,false和true,以及有和没有fontsize参数,它似乎不能工作,因为所有选项都给出了项目属性,如图所示……
以上来自于百度翻译 以下为原文 Jim, I tried that, false and true and with and without the fontsize parameter, seems it did not work as all options gave a project properties as shown... Attached Image(s) |
就在一点点之前,MPLAB X 3.55?在我的Windows 10框/4K,我不再使用任何这些设置
以上来自于百度翻译 以下为原文 As of a little bit ago MPLab X 3.55 ? On my windows 10 box/4k I am no longer using either of these settings |
啊,不,我在3.50,所以我会下载最新的版本,然后再试一次。谢谢:D
以上来自于百度翻译 以下为原文 Ahhh, no I'm on 3.50 so I'll download the latest version and try again. Thanks :D |
好的,所以我下载并安装了3.55,问题相同,我可以张贴属性对话框,但它和我之前张贴的相同。我试着添加mplab_ide.conf文件,我试过true/false和删除--fontsize 24,但是它总是返回相同的值。有什么想法吗?
以上来自于百度翻译 以下为原文 OK, so I downloaded and installed 3.55, the issue is the same, I could post the properties dialogue box but it's identical to the one I posted previously. I've tried adding -J-Dsun.java2d.dpiaware=false --fontsize 24to the mplab_ide.conf file and I've tried true/false and removing the --fontsize 24 but it always comes back the same. Any ideas? |
我想可能需要清除用户的DIR/Cache。
以上来自于百度翻译 以下为原文 I think maybe the user dir/cache needs to be cleared |
帮助,关于弹出窗口显示位置/脏。如果删除内容,它将回到默认安装状态。
以上来自于百度翻译 以下为原文 Help, About the popup window displays the locations/dirs. If you delete the contents it will be back to the default installed state. Any settings/changes you made will be lost. |
这就是我的工作:1。编辑文件“C:程序文件(x86) Microchip MPLABX V3.55 sys javajRe1.80y91bin java.exe”,使用HEX编辑器(我使用HXD)。在改变之前,一定要对它进行备份。2。搜索DPIAAR。3。用“& LT;DPIAVER & GT;FLAST & DL/DPIAVER & G.”替换“& LT;DPIAVER & GT;Trand & Lt/DPIAVER & G.”。因为这个字符串之后有一些空格,您可以在不增加文件大小的情况下替换它(即在它之后的一个较小的空间)。[来自http://Suffux.com/阙…--高DPI-显示]的修改技巧
以上来自于百度翻译 以下为原文 This is what worked for me: 1. Edit the file "C:Program Files (x86)MicrochipMPLABXv3.55sysjavajre1.8.0_91binjavaw.exe" using a HEX editor (I used HxD). Make sure to make a backup of this before changing it. 2. Search for dpiaware. 3. Replace " [Modified trick from https://superuser.com/que...-on-a-high-dpi-display] |
叹息,我删除了我的缓存并更改了java.EXE文件,但仍然是同一个问题。
以上来自于百度翻译 以下为原文 Sigh, I deleted my cache and changed the javaw.exe file but it's still the same issue. |
嗨,伙计们,我来到这个线程有一个类似的问题,但我很快就想起了一个修复,我意识到这样的GUI,没有适当缩放在高分辨率屏幕上的Windows 10。您需要做的是,为MPLAIDIDE的可执行文件兼容设置,并选择重载高DPI缩放行为,并将其设置为系统或系统(增强)(请注意,后者对我来说并不是很好!)这应该使它在你的高分辨率屏幕上显示正确,如果你在其他监视器上有不同的DPI缩放,也允许它在不同的监视器上看起来正确。
以上来自于百度翻译 以下为原文 Hi Guys, I came to this thread with a similar problem, but I soon remembered a fix I became aware of for GUIs like this that didn't scale properly on high resolution screens for Windows 10. All you need to do is to go to the compatibility settings for the executable for MPLAB IDE and select override high DPI scaling behaviour and set it to system or system (enhanced) (note the latter did not work well at all for me!) - this should make it appear properly on your high res screen and, if you have differing DPI scaling on other monitors, allow it to look right on different monitors, too. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:25 , Processed in 0.874335 second(s), Total 78, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3547
