电子发烧友论坛|
嗨,我似乎无法弄清楚将53230A配置为无间隙,连续,持续测量。
要么我必须使用“READ?” 在一个循环中,它有一个~300ms的间隙,或者必须指定一个样本号(它是有限的)。 是否有一个命令用于设置无限测量的计数器(具有给定的选通时间)并使用R? 或数据:REM? 将值传输到计算机? 以上来自于谷歌翻译 以下为原文 Hi, I can't seem to figure out configure the 53230A for gap-free, continuous, ongoing measurement. Either I have to use "READ?" in a loop, which has a ~300ms gap, or have to specify a sample number (which is finite). Is there a command for setting the counter for infinite measurement (with a given gating time) and use R? or DATA:REM? to get transfer the values to the computer? |
4个回答
我正在努力完成同样的事情。
我已经通过CALCulate命令设置了数学函数,但是然后希望计数器连续运行以在一段时间内累积统计数据,然后通过ALL查询停止并读取统计数据。 我现在已经在命令专家中建立了一个序列,但仍然没有实现连续测量。 任何建议? 以上来自于谷歌翻译 以下为原文 I am trying to accomplish the same thing. I have set up math functions through the CALCulate commands but would then like the counter to run continously to accumilate statistics for a period of time, then stop and read the stats throug the ALL query. I have set up a sequence in command expert for now but still have not achived contiuous measurement. Any advice? |
有例子吗?
一个方框图值一百万字;-) 以上来自于谷歌翻译 以下为原文 Is an example available? A block diagram is worth a million words ;-) |
根据原始问题,是否可以进行连续无间隙测量。
SAMPLE:COUNT允许最多1,000,000个点,但是因为在使用R获取期间可以读取读数吗? 应该可以避免内存溢出,从而允许任意数量的点? 菲尔 以上来自于谷歌翻译 以下为原文 Is it possible to have continuous gap-free measurement, as per the original question. The SAMPLE:COUNT allow a maximum of 1,000,000 points, but since the readings can be read during acquisition using R? it should be possible to avoid memory overflow and thus allow an arbitrary number of points? Phil |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:46 , Processed in 0.733433 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2035
