电子发烧友论坛|
可能引起关注的人,感谢您对此帖的关注。
我最近使用PNA-X N5245A来测量非比例值,如A,B,C,D。但是,当我们使用幅度(线性和非线性)时,我发现测量值是正确的。 但是我们发现相应的实/虚值没有明确定义。 您是否介意将转换公式从其幅度/阶段公布为实/虚。 实际测得的信号是电压还是电流? 最好,达 以上来自于谷歌翻译 以下为原文 To Whom It May Concern, Thank you for your attention on this post. I recently use PNA-X N5245A to measure unratioed values, like A, B, C, D. However, I found the measurement values are correct when we are using magnitude (either linear and nonlinear). But we found the corresponding real/imaginary value is not clearly defined. Would you mind to disclose the conversion formula from their magnitude/phase to real/imaginary. And what is actually the measured signal is, the voltage or current? Best, Da |
1个回答
测量信号a~n~或b~n~,其中a和b是每个端口n处的入射波和反射波,定义为| a | ^ 2 ^或| b | ^ 2 ^是均方根功率
以毫瓦为单位。 因此,信号被定义为Vrms / sqrt(1000 * Z0)。 要找到幅度| a | ^ 2 ^ = re ^ 2 ^ + im ^ 2 ^要找到相位,设置相位(a)= arctan(im / re)。 但是,在大多数VNA上,单通道测量的相位将在逐个扫描的基础上确定(PNA-X确实具有相干接收器,因此在某些模式下,您可以查看单通道相位与频率,实际上)。 以上来自于谷歌翻译 以下为原文 The measured signal, a~n~ or b~n~, where a and b are the incident and reflected waves at each port n, are defined such that |a|^2^ or |b|^2^ is the rms power in milliwatts. Thus, the signal is devined as Vrms/sqrt(1000*Z0). To find the magnitude |a|^2^=re^2^+im^2^ To find the phase, set phase(a)=arctan(im/re). But, on most VNAs, the phase of a single-channel measurment will be undetermined on a sweep by sweep basis (PNA-X does have coherent receivers, so in some modes, you can view single channel phase vs frequency, in fact). |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:37 , Processed in 0.508316 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2090
