设置DMM以读取一组34932A矩阵通道的最佳方法是什么?ROUT:CLOSE似乎一次只设置一个开关对。
我们必须在组中的每个开关对之后进行DMM读取,还是有办法像mux模块那样扫描一组通道? 以上来自于谷歌翻译 以下为原文 What's the best way to setup the DMM to read a group of 34932A matrix channels? The ROUT:CLOSE appears to only set one switch pair at a time. Must we do a DMM read after each switch pair in the group, or is there a way to scan a set of channels like we can with the mux modules? |
2个回答
ROUT:CLOSE(@)命令采用频道列表,因此您可以同时关闭多个频道。
但是,您无法使用矩阵卡扫描通道。 但是,您可以定义ROUT:CLOS(@ch_list>),MEAS ...,ROUT ... MEAS序列,并根据需要重复使用。 见ROUT:SEQ:DEFine。 这样,您就可以有效地扫描您正在使用的矩阵卡通道的组合。 这是唯一有意义的方法,因为有很多可能的矩阵通道组合。 以上来自于谷歌翻译 以下为原文 The ROUT:CLOSE (@) command takes a channel list so you can close multiple channels at the same time. However you can't scan channels with a matrix card. However you can define a ROUT:CLOS (@ch_list>), MEAS...,ROUT...MEAS sequence and resuse that as often as you want. See ROUT:SEQ:DEFine. This way you can effectively scan the combinations of matrix card channels that you are using. That is the only way that makes sense since there are so many possible combinations of matrix channels. |
只有小组成员才能发言,加入小组>>
1296 浏览 0 评论
2377 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1132浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
759浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
941浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 09:02 , Processed in 1.726377 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
