电子发烧友论坛|
嘿所有,我无法识别SCPI命令,这将允许我将分析仪屏幕的屏幕截图保存到我PC上指定目录中的文件中。
我正在使用带有Command Expert的N9010A信号分析器,我只需要将屏幕截图保存为.PNG文件类型的文件夹。 提前致谢! 以上来自于谷歌翻译 以下为原文 Hey all, I am having trouble identifying an SCPI command that will allow me to save a screenshot of my analyzer screen to a file in a designated directory on my PC. I am using a N9010A Signal Analyzer with Command Expert and I simply need to save a screenshot to a folder as a .PNG file type. Thanks in advance! |
4个回答
嗨 - 我们有一个使用VEE如何做到这一点的例子。
如果您有VEE,请参阅http://www.home.agilent.com/sec/editorial.jspx?cc=US&lc=eng&ckey=827222&nid=-33932.710346.02&id=827222。 如果您没有VEE,我将总结命令:: MMEM:STORE:SCR 'D:\ exa_screen.png '; * WAI! 在EXA的D:驱动器上存储屏幕的副本。 :MMEM:数据? 'D:\ exa_screen.png '! 通过GPIB,LAN或USB读取文件数据。 这是二进制块数据格式。 :MMEM:DEL 'D:\ exa_screen.png '! 删除EXA的D:驱动器* CLS上的文件! 清除任何状态字节使用:MMEM:DATA查询接收的数据应保存为扩展名为.PNG的二进制文件。 我希望这可以帮到你 - 以上来自于谷歌翻译 以下为原文 Hi - We have an example of how to do this using VEE. If you have VEE refer to http://www.home.agilent.com/sec/editorial.jspx?cc=US&lc=eng&ckey=827222&nid=-33932.710346.02&id=827222. If you do not have VEE, I will summarize the commands: :MMEM:STORE:SCR ’D:\exa_screen.png’;*WAI ! Stores a copy of the screen on the D: drive of the EXA. :MMEM:DATA? ’D:\exa_screen.png’ ! Reads the file data via GPIB, LAN, or USB. This is a binary block data format. :MMEM:DEL ’D:\exa_screen.png’ ! Deletes the file on the EXA’s D: drive *CLS ! Clear any status bytes The data that is received using the :MMEM:DATA query should be saved as a binary file with the extension of .PNG. I hope this was helpful - |
醉狼工作室 发表于 2019-5-16 18:48 嗨Tabbot-是的,完美的工作! 我不确定你是否可以,但我也需要在我的分析仪上使用“Auto Tune”软键进行指导,这样一旦我从发生器中调用状态,它就会在显示屏的参数范围内可见。 如果您可以指导我任何资源或向我提供任何帮助,将不胜感激! 提前致谢 以上来自于谷歌翻译 以下为原文 Hi Tabbot- Yes that worked perfectly! I am not sure if you can, but I also need guidance in using the "Auto Tune" softkey on my analyzer so that once I recall a state from the generator it is visible within the parameters of the display screen. If you could direct me to any resource or provide me with any help that would be greatly appreciated! Thanks in advance |
60user139 发表于 2019-5-16 19:04 很高兴这样做 - 执行自动调谐的SCPI命令是“[:SENSe]:FREQuency:TUNE:IMMediate”。通常,如果你想学习SCPI命令以获得等效的前面板功能,请按“帮助”和 然后是相应的硬键或软键。问候 - 以上来自于谷歌翻译 以下为原文 Glad this is working out - The SCPI command to perform an Auto Tune is “[:SENSe]:FREQuency:TUNE:IMMediate". In general, if you want to learn the SCPI command for an equivalent front-panel function, press Help and then the appropriate hard key or softkey. Regards - |
醉狼工作室 发表于 2019-5-16 18:48 HI如何将二进制块数据格式转换为PNG文件谢谢 以上来自于谷歌翻译 以下为原文 HI How can i convert binary block data format to PNG file thanks |
只有小组成员才能发言,加入小组>>
237 浏览 0 评论
1859 浏览 0 评论
2752 浏览 1 评论
2655 浏览 1 评论
2477 浏览 5 评论
1859浏览 0评论
431浏览 0评论
249浏览 0评论
/9
GMT+8, 2025-12-11 11:15 , Processed in 0.958638 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1243
