在通过SCPI命令执行CalAll时,我们看到一条信息性消息出现:1285,SCPI命令导致错误+182,自定义校准类型不支持远程会话。
我无法在任何地方找到任何对错误182的引用?! [手册在176停止。]有人可以详细说明此错误消息吗? 更具体地说,可能导致它的原因是什么? 我没有跟踪它到特定的命令,但我相信它是SYST:CAL:ALL:CSET:PREFix'xxx' 以上来自于谷歌翻译 以下为原文 While performing CalAll via SCPI commands, we are seeing an informational message appear: 1285, SCPI command caused error +182, The custom cal type does not support remote sessions. I can not find any reference to error 182 anywhere?! [The manual stops at 176.] Can someone elaborate on this error message? And more specifically what may be causing it? I haven't tracked it to a specific command but I believe it is SYST:CAL:ALL:CSET:PREFix 'xxx' |
2个回答
再次找到*我们的*违规代码。
出现此错误的命令是SENS:CORR:TCOL:USER VAL xxx,它被应用于错误的通道,默认为通道1.需要修改以应用于正确的通道。 以上来自于谷歌翻译 以下为原文 Found *our* offending code again. The command that was casuing this error was SENS:CORR:TCOL:USER VAL xxx which was being applied to the wrong channel, by default channel 1. Needed to be modified to apply to the correct channel. |
潇枫2016 发表于 2018-11-6 09:52 感谢更新。 SCPI cal命令有点奇怪,因为有些命令在过去没有通道关联。 因此,如果Chan 2是唯一的活动通道,并且您尝试校准我们将允许它。 然后我认为其他一些事情需要通过渠道来设定。 我不记得肯定但我认为我们现在已经添加了频道关联,如果它是明确的,但不要引用我。 以上来自于谷歌翻译 以下为原文 Thanks for the update. SCPI cal commands are a little odd in that some commands didn't, in the past, have a channel association. So if Chan 2 is the only active channel, and you tried to calibrate we would allow it. Then I think some other things needed to be set by channel. I don't remember for sure but I think we now have added channel association if it is explicit, but don't quote me on that. |
只有小组成员才能发言,加入小组>>
1272 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2944 浏览 3 评论
1091浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
746浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
912浏览 0评论
1276浏览 0评论
GMT+8, 2024-12-20 02:37 , Processed in 1.493299 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
