电子发烧友论坛|
嗨伙计:
我在sparton3e入门套件板上的EDK9.2中设计了一个带lwip3.0的服务器。 执行后,它只是在“lwip_accepte()”的表达时被阻止。 我尝试了许多方法来连接它,如telnet,web浏览器和java中的程序。 但服务器对我的工作没有任何作用。 该怎么办? 我尝试用gdb调试它,但它只是停在那一点。 我该如何调试问题? 顺便问一下,有没有像webserve或者echo服务器这样的sparton3s500e入门套件板的例子?我所得到的所有例子都无法在我的电路板上执行。 谁能给我一个设计? 提前谢谢。消息由nkzhangzx编辑于04-23-2008 01:49 AMMessage由nkzhangzx编辑于04-23-2008 01:52 AM 以上来自于谷歌翻译 以下为原文 Hi folks: I have designed a server with lwip3.0 in EDK9.2 on sparton3e starter kit board. After executed, it is just blocked at the expretion of "lwip_accepte()". I have tried many methods to connect to it such as telnet, web brower and a program in java. But the server does nothing to my work. What should I do with the problem? I try to debug it with gdb, but it just stop at that point. How can I debug the problem? By the way, are there any examples such as a webserve or a echo server for sparton3s500e starter kit board? None of the examples I have got can't execute on my board. Could anyone give me a design? Thank you in advance. Message Edited by nkzhangzx on 04-23-2008 01:49 AM Message Edited by nkzhangzx on 04-23-2008 01:52 AM |
1个回答
我有类似的问题;
我的设计基于Memec板的AvNet示例。 董事会很好地回应了ping,没有http连接或其他任何东西。 它也陷入了接受连接的困境。 我在软件平台配置中打开了lwip的调试选项,并在收到数据包时发现错误:它无法创建信号量 - 显然我没有在xilkernel配置中设置足够高的值。 您应该检查在xilkernel配置中是否有足够的信号量,定时器和内存集。 以上来自于谷歌翻译 以下为原文 I had a similar problem; based my design on AvNet example for Memec board. The board responded to ping very well, no http connection or anything else though. It also got stuck at accepting connections. I turned on the debug options for lwip in software platform configuration and noticed an error when receiving packets: it couldn't create a semaphore - apparently I haven't set the value high enough in xilkernel configuration. You should probably check if you have enough semaphores, timers and memory set in xilkernel configuration. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:56 , Processed in 1.036284 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8775
