if (EthInitStatus == 0)
{ LCD_SetTextColor(Red); LCD_DisplayStringLine(Line5, (uint8_t*)" Ethernet Init "); LCD_DisplayStringLine(Line6, (uint8_t*)" failed "); while(1); } |
****************************************************************************** * @file stm32f2x7_eth_bsp.c * @author MCD Application Team * @version V1.1.0 * @date 07-October-2011 * @brief STM32F2x7 Ethernet hardware configuration. ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * © COPYRIGHT 2011 STMicroelectronics ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "stm32f2x7_eth.h" #include "stm32f2x7_eth_bsp.h" #include "main.h" /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ __IO uint32_t EthInitStatus = 0; __IO uint8_t EthLinkStatus = 0; /* Private function prototypes -----------------------------------------------*/ static void ETH_GPIO_Config(void); static void ETH_NVIC_Config(void); static void ETH_MACDMA_Config(void); /* Private functions ---------------------------------------------------------*/ /** * @brief ETH_BSP_Config * @param None * @retval None */ void ETH_BSP_Config(void) { /* Configure the GPIO ports for ethernet pins */ ETH_GPIO_Config(); /* Config NVIC for Ethernet */ ETH_NVIC_Config(); /* Configure the Ethernet MAC/DMA */ ETH_MACDMA_Config(); if (EthInitStatus == 0) { LCD_SetTextColor(Red); LCD_DisplayStringLine(Line5, (uint8_t*)" Ethernet Init "); LCD_DisplayStringLine(Line6, (uint8_t*)" failed "); while(1); } /* Configure the PHY to generate an interrupt on change of link status */ Eth_Link_PHYITConfig(DP83848_PHY_ADDRESS); /* Configure the EXTI for Ethernet link status. */ Eth_Link_EXTIConfig(); } /** * @brief Configures the Ethernet Interface * @param None * @retval None */ static void ETH_MACDMA_Config(void) { ETH_InitTypeDef ETH_InitStructure; /* Enable ETHERNET clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx | RCC_AHB1Periph_ETH_MAC_Rx, ENABLE); /* Reset ETHERNET on AHB Bus */ ETH_DeInit(); /* Software reset */ ETH_SoftwareReset(); /* Wait for software reset */ while (ETH_GetSoftwareResetStatus() == SET); /* ETHERNET Configuration --------------------------------------------------*/ /* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */ ETH_StructInit(Ð_InitStructure); /* Fill ETH_InitStructure parametrs */ /*------------------------ MAC -----------------------------------*/ ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable; //ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Disable; // ETH_InitStructure.ETH_Speed = ETH_Speed_10M; // ETH_InitStructure.ETH_Mode = ETH_Mode_FullDuplex; ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable; ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable; ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable; ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable; ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable; ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable; ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect; ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect; #ifdef CHECKSUM_BY_HARDWARE ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable; #endif /*------------------------ DMA -----------------------------------*/ /* When we use the Checksum offload feature, we need to enable the Store and Forward mode: the store and forward guarantee that a whole frame is stored in the FIFO, so the MAC can insert/verify the checksum, if the checksum is OK the DMA can handle the frame otherwise the frame is dropped */ ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable; ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable; ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable; ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable; ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable; ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable; ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable; ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable; ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat; ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat; ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1; /* Configure Ethernet */ EthInitStatus = ETH_Init(Ð_InitStructure, DP83848_PHY_ADDRESS); /* Enable the Ethernet Rx Interrupt */ ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE); } /** * @brief Configures the different GPIO ports. * @param None * @retval None */ void ETH_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIOs clocks */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOI | RCC_AHB1Periph_GPIOG | RCC_AHB1Periph_GPIOH | RCC_AHB1Periph_GPIOF, ENABLE); /* Enable SYSCFG clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure MCO (PA8) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; GPIO_Init(GPIOA, &GPIO_InitStructure); /* MII/RMII Media interface selection --------------------------------------*/ #ifdef MII_MODE /* Mode MII with STM322xG-EVAL */ #ifdef PHY_CLOCK_MCO /* Output HSE clock (25MHz) on MCO pin (PA8) to clock the PHY */ RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1); #endif /* PHY_CLOCK_MCO */ SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII); #elif defined RMII_MODE /* Mode RMII with STM322xG-EVAL */ SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_RMII); #endif /* Ethernet pins configuration ************************************************/ /* ETH_MDIO -------------------------> PA2 ETH_MDC --------------------------> PC1 ETH_PPS_OUT ----------------------> PB5 ETH_MII_CRS ----------------------> PH2 ETH_MII_COL ----------------------> PH3 ETH_MII_RX_ER --------------------> PI10 ETH_MII_RXD2 ---------------------> PH6 ETH_MII_RXD3 ---------------------> PH7 ETH_MII_TX_CLK -------------------> PC3 ETH_MII_TXD2 ---------------------> PC2 ETH_MII_TXD3 ---------------------> PB8 ETH_MII_RX_CLK/ETH_RMII_REF_CLK---> PA1 ETH_MII_RX_DV/ETH_RMII_CRS_DV ----> PA7 ETH_MII_RXD0/ETH_RMII_RXD0 -------> PC4 ETH_MII_RXD1/ETH_RMII_RXD1 -------> PC5 ETH_MII_TX_EN/ETH_RMII_TX_EN -----> PG11 ETH_MII_TXD0/ETH_RMII_TXD0 -------> PG13 ETH_MII_TXD1/ETH_RMII_TXD1 -------> PG14 */ /* Configure PA1, PA2 and PA7 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_7; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH); /* Configure PB5 and PB8 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_8; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_ETH); /* Configure PC1, PC2, PC3, PC4 and PC5 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH); /* Configure PG11, PG14 and PG13 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_13 | GPIO_Pin_14; GPIO_Init(GPIOG, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOG, GPIO_PinSource11, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOG, GPIO_PinSource13, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOG, GPIO_PinSource14, GPIO_AF_ETH); /* Configure PH2, PH3, PH6, PH7 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_6 | GPIO_Pin_7; GPIO_Init(GPIOH, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOH, GPIO_PinSource2, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOH, GPIO_PinSource3, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOH, GPIO_PinSource6, GPIO_AF_ETH); GPIO_PinAFConfig(GPIOH, GPIO_PinSource7, GPIO_AF_ETH); /* Configure PI10 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOI, &GPIO_InitStructure); GPIO_PinAFConfig(GPIOI, GPIO_PinSource10, GPIO_AF_ETH); } /** * @brief Configures and enable the Ethernet global interrupt. * @param None * @retval None */ void ETH_NVIC_Config(void) { NVIC_InitTypeDef NVIC_InitStructure; /* 2 bit for pre-emption priority, 2 bits for subpriority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /* Enable the Ethernet global Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = ETH_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /** * @brief Configure the PHY to generate an interrupt on change of link status. * @param PHYAddress: external PHY address * @retval None */ uint32_t Eth_Link_PHYITConfig(uint16_t PHYAddress) { uint32_t tmpreg = 0; /* Read MICR register */ tmpreg = ETH_ReadPHYRegister(PHYAddress, PHY_MICR); /* Enable output interrupt events to signal via the INT pin */ tmpreg |= (uint32_t)PHY_MICR_INT_EN | PHY_MICR_INT_OE; if(!(ETH_WritePHYRegister(PHYAddress, PHY_MICR, tmpreg))) { /* Return ERROR in case of write timeout */ return ETH_ERROR; } /* Read MISR register */ tmpreg = ETH_ReadPHYRegister(PHYAddress, PHY_MISR); /* Enable Interrupt on change of link status */ tmpreg |= (uint32_t)PHY_MISR_LINK_INT_EN; if(!(ETH_WritePHYRegister(PHYAddress, PHY_MISR, tmpreg))) { /* Return ERROR in case of write timeout */ return ETH_ERROR; } /* Return SUCCESS */ return ETH_SUCCESS; } /** * @brief EXTI configuration for Ethernet link status. * @param PHYAddress: external PHY address * @retval None */ void Eth_Link_EXTIConfig(void) { GPIO_InitTypeDef GPIO_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* Enable the INT (PB14) Clock */ RCC_AHB1PeriphClockCmd(ETH_LINK_GPIO_CLK, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); /* Configure INT pin as input */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_Pin = ETH_LINK_PIN; GPIO_Init(ETH_LINK_GPIO_PORT, &GPIO_InitStructure); /* Connect EXTI Line to INT Pin */ SYSCFG_EXTILineConfig(ETH_LINK_EXTI_PORT_SOURCE, ETH_LINK_EXTI_PIN_SOURCE); /* Configure EXTI line */ EXTI_InitStructure.EXTI_Line = ETH_LINK_EXTI_LINE; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); /* Enable and set the EXTI interrupt to the highest priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /** * @brief This function handles Ethernet link status. * @param None * @retval None */ void Eth_Link_ITHandler(uint16_t PHYAddress) { /* Check whether the link interrupt has occurred or not */ if(((ETH_ReadPHYRegister(PHYAddress, PHY_MISR)) & PHY_LINK_STATUS) != 0) { EthLinkStatus = ~EthLinkStatus; #ifdef USE_LCD /* Set the LCD Text Color */ LCD_SetTextColor(Red); if(EthLinkStatus != 0) { /* Display message on the LCD */ LCD_DisplayStringLine(Line5, (uint8_t*)" Network Cable is "); LCD_DisplayStringLine(Line6, (uint8_t*)" unplugged "); } else { /* Display message on the LCD */ LCD_DisplayStringLine(Line5, (uint8_t*)" Network Cable is "); LCD_DisplayStringLine(Line6, (uint8_t*)" now connected "); } #endif } } /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/ |
我现在正在用这个,你能不能给我发一下你的源代码,我做的是通过这个上传到yeelink
这就是官方demo与实际项目的差距!
采用一个低优先级任务去初始化,让任务去等待网络连接,这样等网络连接后,可以初始化成功,而且网线插拔都可以正常使用。
void ETH_BSP_Config(void) { /* Configure the GPIO ports for ethernet pins */ ETH_GPIO_Config(); /* Configure the Ethernet MAC/DMA */ ETH_MACDMA_Config(); /*此处一直等待网络连接,直到网络连接成功,且初始化通过*/ while(!EthInitStatus) { OSTimeDly(100); //调用OS函数,任务等待,释放CPU控制权 Eth_Phy_Init(); //对PHY初始化 } /* Config NVIC for Ethernet */ ETH_NVIC_Config(); } static void ETH_MACDMA_Config(void) { ETH_InitTypeDef ETH_InitStructure; /* Enable ETHERNET clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx | RCC_AHB1Periph_ETH_MAC_Rx, ENABLE); /* Reset ETHERNET on AHB Bus */ ETH_DeInit(); /* Software reset */ ETH_SoftwareReset(); /* Wait for software reset */ while (ETH_GetSoftwareResetStatus() == SET); Eth_Phy_Init(); } void Eth_Phy_Init(void) { /* ETHERNET Configuration --------------------------------------------------*/ /* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */ ETH_StructInit(Ð_InitStructure); /* Fill ETH_InitStructure parametrs */ /*------------------------ MAC -----------------------------------*/ ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable; //ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Disable; // ETH_InitStructure.ETH_Speed = ETH_Speed_10M; // ETH_InitStructure.ETH_Mode = ETH_Mode_FullDuplex; ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable; ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable; ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable; ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable; ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable; ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable; ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect; ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect; #ifdef CHECKSUM_BY_HARDWARE ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable; #endif /*------------------------ DMA -----------------------------------*/ /* When we use the Checksum offload feature, we need to enable the Store and Forward mode: the store and forward guarantee that a whole frame is stored in the FIFO, so the MAC can insert/verify the checksum, if the checksum is OK the DMA can handle the frame otherwise the frame is dropped */ ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable; ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable; ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable; ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable; ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable; ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable; ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable; ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable; ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat; ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat; ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1; /* Configure Ethernet */ EthInitStatus = ETH_Init(Ð_InitStructure, DP83848_PHY_ADDRESS); /*此处增加初始化状态判断*/ if(!EthInitStatus) return; /* Enable the Ethernet Rx Interrupt */ ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE); } |
你好。我现在也在调试这个,你解决了吗,可以发个代码学习学习吗。QQ 2902926270
我的f4板子拔出网线,EXTI15_10_IRQHandler没有调用,不知道为什么
我也在调试。可以用了,但是网线插入之后,中断不一定能上来。
不知道原因?谁能解答一下。 我用万用表测试7脚的输出电压,发现只能变化一次,后来再无变化。(这个还是取决于代码Eth_Link_PHYITConfig(DP83848_PHY_ADDRESS);的定义,否则,一点都不变化) 是否我的思路有问题?谢谢。 |
不插网线不可能初始化。这就是这样的,不插网线上电干什么
终于搞定啦。。。。。。。。。。。
我还在调试,还是存在问题。不好意思啊。惊喜折半。
我在 STM32F107 上已经实现了,和你的问题描述有点不一样:不插网线初始化LWIP,臣妾做不到... 插入网线正常通信,臣妾做到了这个是:不插网线开机,定时5s不断初始化网口,一旦插上网线并且网口初始化成功后再初始化LWIP。之后就可以正常运行,热插拔也没问题。
项目上正在使用,目前没什么问题。 用了ucosii 的官方例程或者大神们移植的程序 首先在BSP_Init() 中找到 ETH_BSP_Config();再找到 Ethernet_Configuration();(程序中我注释了,原因是把这个函数放到任务中定时调用) void ETH_BSP_Config (void) { /* Configure the GPIO ports for ethernet pins */ ETH_GPIO_Config(); /* Config NVIC for Ethernet */ ETH_NVIC_Config(); /* Configure the Ethernet peripheral */ // Ethernet_Configuration(); } 打开 Ethernet_Configuration();找到 ETH_Init(Ð_InitStructure, PHY_ADDRESS);这个函数是初始化网口的,是否连接上网口这个函数返回值不同 用 ETH_Link_Flage 在任务中判断网口是否初始化成功(是否插上网线),连上了就删除初始化网口的任务。以后不管插拔网线都可以连上 建议去仔细看看 uint32_t ETH_Init(ETH_InitTypeDef* ETH_InitStruct, uint16_t PHYAddress) 中干了什么!!! void Ethernet_Configuration (void) { . . . . /* Configure Ethernet */ ETH_Link_Flage = ETH_Init(Ð_InitStructure, PHY_ADDRESS); /* Enable the Ethernet Rx Interrupt */ ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE); } 下面是初始话网口的任务 void Net_Init (void *pdata) { extern u8 ETH_Link_Flage while(1) { if(ETH_Link_Flage == 1) { LwIP_Init(); LwIP_Pkt_Sem = OSSemCreate(0); OSTaskCreate(LwIP_Pkt_task, (void *)NULL, (OS_STK *)&LwIP_Pkt_Task_STK[LwIP_Pkt_STK_Size-1], LwIP_Task_PRIO); OSTaskDel(NetInit_TASK_PRIO); } else { Ethernet_Configuration(); } OSTimeDlyHMSM(0,0,5,0); } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1477 浏览 1 评论
1137 浏览 0 评论
1001 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5380 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4168 浏览 1 评论
浏览过的版块 |
/9
GMT+8, 2025-12-15 14:06 , Processed in 1.659617 second(s), Total 102, Slave 85 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3225
