电子发烧友论坛|
你好,
关于Master / Slave核心我有一个问题:http://asicFPGA.com/site_upgrade/asicfpga/pds/mcu_pds_files/xapp315.pdf 问题是,当我将核心(从中移除了uC接口)连接到FSM时,只要数据(第一次发送!)被发送,SCL线就会浮动(2V)。 SCL线通过2k2电阻上拉至3.3V。 我的建议是我没有正确配置MSTA(一旦我发送数据,MSTA的RST值= 0我设置该位,下一个状态将数据提供给IP内核)。 任何人都可以帮助我吗?我没有任何线索。 FPGA引脚没有损坏,因为当我连接一个简单的I2C fsm时,SCL线是正确的。 问候 以上来自于谷歌翻译 以下为原文 Hello, I've got a problem regarding a Master/Slave core : http://asicfpga.com/site_upgrade ... s_files/xapp315.pdf The problem is that when i connect the core (which a removed the uC interface from) to the FSM i use the SCL line is floating (2V) as soon as data (the first bite!) is send. The SCL line is pulled up with a 2k2 resistor to 3.3V. My suggestion is that I do not configure MSTA right (RST value of MSTA = 0 as soon as i send data I set the bit and the next state gives data to the IP core). Can anyone help me?I haven't got a clue. The FPGA pins are not broken, because when i connect a simple I2C fsm the SCL line is right. greetings |
7个回答
您是否看过您的焊盘报告以确保SCL引脚位于右侧引脚上?
如果SCL定义为内部上拉,则不需要减少SCL 外部电阻。 如果它被弱化,那就不是软件问题了 配置后,上拉或下拉不会改变。 另一件事 尝试生成网表,默认IOB设置为拉起而不是下拉。 如果这改变了行为,则不会在正确的引脚上获得SCL。 - Gabor 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Did you look at your pad report to make SURE that the SCL pin is on the right pin? If your SCL is defined with an internal pullup, you should not need to reduce your external resistor. If it is getting pulled down weakly, it is not a software issue,as the pullup or pulldown does not change after configuration. Another thing to try is to generate the netlist with the default IOB set to pull up instead of down. If this changes the behavior you are not getting SCL on the right pin. -- GaborView solution in original post |
由于你有一个2.2K电阻到3.3V,我建议SCL线是
实际上并非“浮动”而是微弱地拉下来。 是否有可能 内核是否已将引脚配置为下拉或保持器? 您可以在FPGA编辑器中进行检查。 - Gabor 以上来自于谷歌翻译 以下为原文 Since you have a 2.2K resistor to 3.3V, I would suggest that the SCL line is not actually "floating" but rather weakly pulled down. Is it possible that the core has caused the pin to be configured with a pull-down or keeper? You can check this in the FPGA editor. -- Gabor |
好吧,我在ISE中看到SCL也被配置为3.3V的上拉和硬件以及单独的(固件中的硬件和引脚)。
它没有任何帮助。 同样的问题不断发生。 以上来自于谷歌翻译 以下为原文 Well, I looked in ISE en configured SCL also as a Pull-up to 3.3V and in hardware and also seperatly (hardware and pin in firmware). It doesn't help anything. the same problem keeps occuring. |
另一件事也可以在FPGA编辑器中看到。
确保您的SCL引脚未从设计中移除或 搬到另一个别针。 未使用的IOB的默认操作是添加 下拉电阻,可能会导致您看到的症状。 如果来自核心的名称没有,SCL可以移动到不同的引脚 例如,匹配.ucf文件中的引脚名称。 问候, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 One other thing which may also be seen in the FPGA editor. Make sure that your SCL pin has not been removed from the design or moved to another pin. The default action for unused IOB's is to add a pulldown resistor, which could cause the symptoms you are seeing. SCL could move to a different pin if the name from the core does not match the pin name in your .ucf file for example. Regards, Gabor -- Gabor |
你好Gabor,
我真的很感谢你帮助我! 但问题还没有解决! 我查看了我的.ucf文件,这是正确的。 名称(包括capitel Letters)是100%相同。 引脚也连接到它。 我用200欧姆减小了电阻,现在电压电平足够高,以便从机对应时钟信号。 但这不是解决方案,因为只有浮动电平更高(0.2V)。 我不认为这是硬件问题,而是MCBR寄存器的设置或其他东西(在初始时间内是从属的核心?)。 你能告诉我如何设置这个寄存器来执行作为主人的操作吗? 1件事是我不看任何中断信号,我只想通过总线作为主设备发送数据,并将从设备数据作为主设备(我正在连接DS1631 temp.sens。)。 我可以看到SDA线是正确的,并正确拉到3.3V。 再次感谢你的帮助! 射线 消息由404278编辑于01-15-2009 06:52 AM 以上来自于谷歌翻译 以下为原文 Hello Gabor, I really appreciate you help me! But the problem isn't fixed yet! I looked in my .ucf file and that is correct. The name (including capitel Letters) is 100% the same. Also the pin i connected it to. I reduced my resistor with 200 ohms and now the voltage level is high enough for the slave to correspond on the clock signal. But that's not the solution, because only the floating level is higher (0.2V). I don't think it's a hardware problem but the settings of the MCBR registers or something (is the core a slave in initial time?). Can you tell me how to set this register to perform actions as a master? 1 thing is that i don't look at any interrupt signals, i just want to send data over the bus as a master, and gate the slave data as a master (I'm interfaceing a DS1631 temp.sens.). I can see the SDA line is correct and is correctly pulled op to 3.3V. Thanks again for your help! Ray Message Edited by 404278 on 01-15-2009 06:52 AM |
如果SCL定义为内部上拉,则不需要减少SCL 外部电阻。 如果它被弱化,那就不是软件问题了 配置后,上拉或下拉不会改变。 另一件事 尝试生成网表,默认IOB设置为拉起而不是下拉。 如果这改变了行为,则不会在正确的引脚上获得SCL。 - Gabor 以上来自于谷歌翻译 以下为原文 Did you look at your pad report to make SURE that the SCL pin is on the right pin? If your SCL is defined with an internal pullup, you should not need to reduce your external resistor. If it is getting pulled down weakly, it is not a software issue,as the pullup or pulldown does not change after configuration. Another thing to try is to generate the netlist with the default IOB set to pull up instead of down. If this changes the behavior you are not getting SCL on the right pin. -- Gabor |
嗨Gabor,
感谢您的信息! 我解决了问题! 该线路连接到我未在.ucf中定义的输入引脚。 那个针被拉下来了。 所以你是对的! 这是硬件! 日Thnx 射线 以上来自于谷歌翻译 以下为原文 Hi Gabor, Thanks for the information! I got the problem solved! The line was connected to an input pin i didn't define in the .ucf. That pin was pulled down. So you were right! It was hardware! thnx Ray |
只有小组成员才能发言,加入小组>>
3137 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1353浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1191浏览 1评论
/9
GMT+8, 2025-12-9 02:26 , Processed in 0.965053 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7358
