扫一扫,分享给好友
嗨,所有的刺激可以指示或记录哪些条件已经被检测或触发发射?我一直在寻找这个特性,但我没有找到它。如果不可用,您如何验证刺激同步动作实际上是正确工作的?
以上来自于百度翻译 以下为原文 Hi all, Can Stimulus indicate or log which conditions have been detected or triggers fired? I have been searching for this feature and I don't find it. If it is not available, how do you verify that Stimulus synchronous actions are actually working correctly? |
2个回答
我注意到,如果我手动刺激,它会在“模拟器”标签下注册“输出”。一些Google建议,这个标签也应该指示同步刺激,但出于某种原因,似乎我没有发生。我使用MPLABX 3.45。我说它不起作用的原因是,我设置了同步刺激,应该触发一个中断。当启用该刺激时,我会反复地得到中断(在ISR中用断点观察),但是当我禁用刺激时,我不会得到中断。因此这表明它们正在触发但未被记录。
以上来自于百度翻译 以下为原文 I have noticed that if I fire a manual stimulation it gets registered in the "Simulator" tab under "Output". Some googling suggests that this tab should also indicate synchronous stimuli, but for some reason it seems that is not happening for me. I am using MPLABX 3.45. The reason I say it doesn't work is that I have set up synchronous stimulus that should trigger an interrupt. When running with that stimulus enabled I do get the interrupts repeatedly (observed by a breakpoint in the ISR), but when I disable the stimulus I do not get the interrupt. So this indicates that they are triggering but not being logged. |
我只能找到异步刺激的选项卡,但是绿色箭头控制按钮有一个工具提示,提示“应用”或“删除同步刺激”。我看到了刺激(拨号端口输入引脚),直到我运行模拟器的另一个指令。你使用时钟刺激?
以上来自于百度翻译 以下为原文 I could only find a tab for asynchronous stimulus, but the green arrow control button has a tooltip that says "Apply" or "Remove Synchronous Stimulus". I see that the stimulus (toggle port input pin) was not applied until I ran the simulator for another instruction. Are you using clock stimulus? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
454 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3529 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1094浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
460浏览 0评论
/9
GMT+8, 2025-12-1 16:20 , Processed in 1.823159 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
811
