电子发烧友论坛|
嗨喜欢xilinx的人。
感谢您听一些关于使用spartan xc3s400ft256:1处理入门套件的问题。 我购买了入门套件。 在我下载xiilinx页面中的时钟项目的最初几天,我放入了Web包,FPGA工作得很好。 然而,有些日子我试图使用相同的项目示例对电路板进行编程,并且web pack编译器显示了我在网络包中没有看到的非常奇怪的错误,而我没有编写fpga。 影响检测到fpga但是在它显示程序有一千个错误之后。 2.此外,我确实感觉到几次静电放电,同时我确实触摸了卡的开关。 我不知道fpga是否支持那些放电或者是否已经明确损坏并且无所事事我会感谢你能帮助我解决这些问题,因为我需要优先考虑我在学院的工作 以上来自于谷歌翻译 以下为原文 Hi people of xilinx. Thanks for listen some questions about the handling of the starter kit with the spartan xc3s400ft256: 1. I purchased the starter kit. In the first days I downloaded the project of clock that was in the xiilinx page, I put in the Web pack and fpga worked perfectly. However, some days i tried to program the board with the same project example, and the web pack compiler showed very strange errors that I have not saw in the web pack and I did not can program the fpga. The impact detect the fpga but after it shows that the program have a thousand of errors. 2. also,I did feel several electrostatic discharges meanwhile I did touch the switches of the card. I do not know if fpga suports those discharges or if already definitively damage and is not anything to do I will be thankful if you can help me with these problems, cause i need to program my works of the college in the board with priority |
1个回答
只要您使用相同的Bit文件即可
最初下载然后通常应该没有问题。 如果你是那么设备可能有 被ESD损坏。 您从iMPACT获得了什么错误? 如果您没有通过模拟验证设计是否正确? 你能尝试编程测试设计(和门或类似) 并查看编程是否成功以及DONE是否变高。 以上来自于谷歌翻译 以下为原文 As long as you are using the same Bit file that youdownloaded initially then normally there should be no issue. If you are then the device may havebeing damaged from the ESD. What errors are you getting from iMPACT? If you are not have you verified via simulation that the design is correct? Can you try programming a test design (AND gate or similar)and see if programming is successful and if DONE goes high. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:09 , Processed in 0.738834 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1468
