扫一扫,分享给好友
你好,
我对使用PSoC 3S感到沮丧的是,它们似乎需要大量的电容器和复杂的电源连接。对于非常空间受限的应用,这些可能会使事情变得困难。QFN48封装显然需要9个电容器,10个电源和7个GND连接! 我的问题是:每个电源连接真的有必要吗?每个电容器真的有必要吗? 例如,如果我只使用象限中的引脚作为模拟输入,需要VDdiO3上的电容器吗?事实上,我甚至需要电源连接吗?我可以只使用一个电容器用于所有的VDDIO管脚吗? 在附加的图像上,您可以看到我的空间受限的PCB,以及它的部分示意图。在原理图上,我从两个VDIO0管脚(13和24)中取出电容器,试图给我一些空间。 雨果 pSoClinux公司 82.8 K 以上来自于百度翻译 以下为原文 Hi, One thing I'm finding frustrating about using the PSoC 3s is that they seem to require a huge number number of capacitors and complex power connections. For very space constrained applications, these can make things difficult. The QFN48 package apparently needs 9 capacitors, 10 power and 7 GND connections ! My question are: Is every power connection really necessary? Is every capacitor really necessary? For example, do I need the capacitor on Vddio3 if I am only going to be using the pins in that quadrant as analog inputs? In fact, do I even need the power connection there? Could I just use one capacitor for all of the Vddio pins? On the attached image, you can see my space constrained PCB, and part of the schematic for it. On the schematic, I have removed the capacitors from two of the Vddio0 pins (13 & 24) to try to give me some space. Hugo
1个回答
简短的回答是没有好的答案。
这就是说,在这里讨论多个电源域的原因。 HTTP://www. CyPress?COM/?DOCID=37266 它有点艺术,而不是科学。如果你的端口轻载,电流和C,你可能会得到。 在几个VDIOS上共享一个耦合帽。如果你做的是高精度 模拟和驱动大量的C和I,可能不是。 不是所有的耦合帽都是相等的,看看它们的规格,尤其是Z VS F.MLC和聚合物鞣剂。 最好的。 祝你好运。 问候,Dana。 以上来自于百度翻译 以下为原文 The short answer is there is no good answer. That being said look here at discussion of reasons for multiple power domains. http://www.cypress.com/?docID=37266 Its a bit art, not science.If your ports lightly loaded, current and C, you may be able to get away with sharing a coupling cap across several Vddios. If you are doing high precision analog and driving lots of C and I, probably not. Not all coupling caps are equal, look at their specs, especially z vs f. MLC and Polymer tanatalum the best. Good luck. Regards, Dana. |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2014 浏览 1 评论
1773 浏览 1 评论
3565 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1707 浏览 6 评论
1474 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
388浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
273浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
365浏览 2评论
307浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
506浏览 2评论
GMT+8, 2024-10-3 09:57 , Processed in 0.805303 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
